87' Delphin 325is LS1: Went to Paint
  • Rc 415
    • Jun 2011
    • 723
    #76
    test fitted front wheel and brake, looks so good
    buuuut i have to figure out a tire, and a massive fender roll in front. rears will get rolled too to fit a 245/45 look at this poke :doh28::bang head:
    1987 Delphin 325IS
    LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
    Build Thread
    1993 alpine 2 325IC
    •Ground control coilovers•16" BBS RS• momo woodgrain
    • Cronopoulos
      • Jul 2011
      • 2187
      #77
      Killer rims, flare time!
      Project log -- DIRTY 30
      2.7i * Megasquirt tuned * E85 powered
      • dmoney(AB)
        • 1372
        #78
        quit test fitting and bolt those suckers on!
        new wheels look sick. I can see that you will have a following!
        mtech1/2jzgte/r154/275tire
        function>form
        • Rc 415
          • Jun 2011
          • 723
          #79
          Tires are ordered, 225/45/16 falken fk-452 all around. 245/45/16 was too hard to fine in a matching set f/r. Better off this way anyway, I can rotate tires.
          Also received these parts yesterday:
          Picking up an extra subframe this weekend to install these and put it in the car.
          1987 Delphin 325IS
          Build Thread
          1993 alpine 2 325IC
          • bmwguy325is
            • May 2011
            • 1262
            #80
            Are the wheels CCW knock offs?
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • Vivek
              attention whore/retard/bitch
              • 6167
              #81
              I don't think they're actually dual drilled. The other 4 holes look like they're there for weight but I'm not sure.
              1992 Mauritiusblau Vert
              2011 Alpinweiss 335is coupe
              2002 540i/6 Black/Black
              2003 GSX-R 750 (RIP)
              • Rc 415
                • Jun 2011
                • 723
                #82
                This is correct.
                1987 Delphin 325IS
                Build Thread
                1993 alpine 2 325IC
                • Mlarsen
                  • 4082
                  #83
                  So what did you end up doing about that manifold issue? Did you end up purchasing a real Revshift manifold?
                  • Rc 415
                    • Jun 2011
                    • 723
                    #84
                    I'm going to go with a twin scroll manifold, most likely the 666 one. I welded the old one up for now, and it works fine.
                    1987 Delphin 325IS
                    Build Thread
                    1993 alpine 2 325IC
                    • SwiftE30
                      • Jun 2010
                      • 998
                      #85
                      those wheels look amazing! where did you get them?
                      1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
                      • einstein57
                        • Jun 2007
                        • 10780
                        #86
                        310mm kit? Any spacers required?
                        www.gecoils.com
                        • Rc 415
                          • Jun 2011
                          • 723
                          #87
                          Negative. Well spacers needed to clear the strut tube with the rim
                          1987 Delphin 325IS
                          Build Thread
                          1993 alpine 2 325IC
                          • einstein57
                            • Jun 2007
                            • 10780
                            #88
                            How big of a spacer did you use? I'm trying to organize a IE BBK figment guide
                            www.gecoils.com
                            • Rc 415
                              • Jun 2011
                              • 723
                              #89
                              Tried 5's they weren't thick enough, seems like 10mm will be the ticket. Keep in mind I did not need spacers for the brakes to fit, just to stop the rim inner lip from hitting the strut tube.
                              1987 Delphin 325IS
                              Build Thread
                              1993 alpine 2 325IC
                              • Rc 415
                                • Jun 2011
                                • 723
                                #90
                                1987 Delphin 325IS
                                Build Thread
                                1993 alpine 2 325IC
