This is Polly, the m30b35 swapped Ratrod.
    This thread keeps getting better and better
      Originally posted by VinniE30 View Post
      This is awesome! M30 FTW I approve 110%
      I miss the power of my e24...now I got it! but even better with the 260/6!!!!
      Originally posted by Swanny View Post
      Ain't no thang! Got those under pulleys to liven up the e39 so its a win win!
      No really man, I know I help out a ton with your e30 and all. But you are a true friend that helps back. Gotta slap those pulleys in this weekend or something. Hit you up soon.
      I got refunds for every part and cores for the engine and transmission.
      Originally posted by lambo View Post
      Holy shit that looks cold...
      34 degrees, I was wearing a Carhartt jacket and coveralls that are insulated. Then I had on wool socks and my triple insulated sole boots with double layer insulate(my feet are insanely toasty). I then had on jeans and a thermal with flannel!
      I am glad you enjoy it! I am getting the m20 running perfect when weather gets better. Then do some basic m30 engine work(seals, gaskets etc). Then swap for a ton more NA HP!!! I am so excited for a b35-206/6.
      This is what I have always wanted to swap but one never popped up with a 5spd.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
        Turbo Turbo Turbo..!!!!!!!!! haha, damn you change your mind so many times. M50-M20-M30.. If you need mounts let me know.
        Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
        ____________________________
        E-mail Panayiotisx2@gmail.com
        Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
          Originally posted by F34R View Post
          Big thanks goes to Sean(Swanny) for covering the additional cost of the swap. Work has been down bad and he stepped up like the great friend he is. Thank buddy!
          This is why i love r3v.
          Also, excellent choice in powerplants!
          Lorin
          The M30 is God's engine.
            This forum is a tight knit, Sean is a great friend even without the help with the engine.
            M30 alone is nasty...add a proper built turbo setup and this will be evil. That is what I am going for.
            YOU are the reason I want a turbo M30. Or any turbo engine for that matter.
            M50 was a go till the back cylinder was found to have sucked a valve chip. Left 1mm slashes, then the m20 was just perfect till I found the m30. I had two m30s before this m20, I just sold them before I found out the m50 was bad. This popped up and I could not say no! The m30 is like 65lbs more? with gobs of NA trq! Kinda sucks I spent all the money and time building that stacked m20. Was fun building it and I am sure someone soon will be happy to swap that in.
            Thanks for the offer on the mounts, I am making them myself.
            Current cars:
            ~ '87 535
            ~ '06 X5 4.8is
              Indeed. I sorely miss my 3.7 liter M30 E30.
              Lorin
                I miss my e24s really bad, I will end up buying another one someday. I got to ride in Tom's m30 swap a year ago. Very fast NA, with the car stripped it would run down a pre 07 WRX(110hp till spool,225 with turbo engaged).
                Current cars:
                ~ '87 535
                ~ '06 X5 4.8is
                  I think m30's are my favorite swaps for the e30.
                  I am so excited.
                    I'm a fan of the m30.
                    Even more so when they are pressurizeddddddddz
                    1991 325iS turbo
                      I'm just going to leave this here, i hope Otis doesn't mind...
                      Lorin
                        I watched all of his videos last night then I watched about 2 hours of M30 turbo videos. I loaded the engine back up today and I am pressure washing it in a bit. Then a mild tear down to inspect the hoses and wiring. Then the normal list of basic gasket and maintenance.
                        Stay tuned, this will be good. I am SO HAPPY I got a clean b35 with the 5spd to turbo :evil:
                        Current cars:
                        ~ '87 535
                        ~ '06 X5 4.8is
                          Rooting for you.
                          Needs more beard though
                          1991 325iS turbo
                            your car wants a cracker. maybe should get off her first.
                            1983 Peugeot 505 STI
                            1992 Volvo 240 Wagon
                              That black e34 is not Polly, that was just the donor.
                              Originally posted by ak- View Post
                              Rooting for you.
                              Thanks! Everything will sort out fast as I have nothing else to do this week. Shooting to swap the engine once the mounts are done. Right now I am cleaning everything like crazy, tomorrow I will remove the hoses and vac parts and see if everything is crack free and ready to go. Then split the block from the bell housing and check the clutch.
                              For you ak- <3
                              Current cars:
                              ~ '87 535
                              ~ '06 X5 4.8is
                                I just got this stuff called dreambeard. You put a couple drops in and rub it in. Makes it very soft, makes it healthier, soften the skin and what not.
                                Shop Products and Apparel for Men by DreamBeard located in Atlanta, Georgia.
                                Get some.
                                I am excited for this motor to go in. some feedback on how the motor is compared to an m20, and if you feel your suspension setup is still adequate for the increased weight.
