Oh and the power comes from the head breathing better with a chip you should be able to rev to 7k
Robbies alpine sedan 5cyl swap
I dont think you can just swap the heads, you need different pistons as well, the i combustion chamber is different than the eta.
The Best stroker guide I have found in one location:
Originally posted by e30lovsweet a mk4 jetta, haven't seen one of them for about 14 seconds
Originally posted by mRodiek View PostI dont think you can just swap the heads, you need different pistons as well, the i combustion chamber is different than the eta.
http://strictlyeta.net/technical/328i_3.html
hmmm could have sworn you could just swap heads and it would be ok but just a lower compression. ill have to do some more research, maybe someone will chime in.
Originally posted by Pantless Spency View Postwow i really like your volvo!!!
based off that i think this build thread will go well
good luck to you sir.
Originally posted by ogbimmer View PostOh and the power comes from the head breathing better with a chip you should be able to rev to 7k
Originally posted by ogbimmer View Postefffff volvospeed!!!! I cant read anymore pages without becoming a member haha. nice job with the changing a head gasket on the side of the road and the e85 stuff
I am putting my motor in a buddys car tommorow, then next weekend my manual swap goes in someone elses car, lucky to get some side work out of selling my parts, just wish i had more time.
ok here is what i found on strictlyeta under the 2.8 stroker page
"However, the stock 325e pistons will not work with the 325i head because of the different design; the 325i has a domed cylinder chamber to match the domed pistons while the eta has a flat cylinder chamber to match the flat pistons. Throw the flat 325e pistons into a 325i head and you have a mismatch that causes a lower compression ratio, and this for this procedure, lowering is a bad thing. So that leaves you with 3 choices: "
So it sounds like leaving the pistons alone is what you want to do to keep the compression low if you want to boost it, so sounds like i should be fine leaving the whole bottom end alone and just swapping an i head.
You should hate that steering wheel too... and send it to me. ;) I would love to take those tan seats off your hands as well! :D Lol Car looks nice! Your Volvo was awesome. I love me some Alphards.-Erik
Originally posted by 87e30I just want to dance with some beezies
Originally posted by Erik View PostYou should hate that steering wheel too... and send it to me. ;) I would love to take those tan seats off your hands as well! :D Lol Car looks nice! Your Volvo was awesome. I love me some Alphards.
i will miss the volvo alot, luckily i am selling almost all the parts to locals in the pnw so i will see parts of my car at the volvo meets/shows and the alphards might be going on my buddies e39....
Originally posted by mdlimy View Postok here is what i found on strictlyeta under the 2.8 stroker page
plenty of people just get Arp head studs and a good tune and roll with it
" WHY DO YOU NEED 300HP TO DO THE SPEED LIMIT?"
Originally posted by ogbimmer View Postyeah man! I would boost that engine while you build another one!. e30s are really fun cars with anything above 200hp, and if you boost about 15psi you should be in the 300 range.
Originally posted by mdlimy View Posttrue, depending on the turbo, but i dont have the time or money right now to do anything, my plan is to get it driving, get it all cleaned up and just work on painting odds and ends and making it looks great, then coilovers and wheels then the vems install then turbo the eta with an i head and roll it and in the mean time either build an m20, m30 or m5x, have yet to decide.
Just let me know if you need any parts! I have alot of stuff lol
Originally posted by mdlimy View PostYou really notice some extra power when dropping the i head on the eta bottom end? i know it drops compression to about 8.3:1 but allows for revving, where is the extra power coming from if there is such a loss in static compression ratio? you make me want to do an i head swap sooner than expected, i figured it would be pointless to do without boost bc of the low compression...~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8is
good to know guys, thanks. i will be doing an i head swap fairly soon just to make the car a bit more enjoyable, im sure i could make some decent na numbers once the vems is installed, atleast better than stock.
Made a bit of progress today, went to the junkyard, they only had one 325 and it was an e so i grabbed the throttle body i needed. The whole harness, ecu and guage cluster was gone so i still need to grab all that. I called around the only other 3 yards and none of them have any I's =[
I grabbed the rear heater hoses and that little valve setup from the 325e at the yard, i still use that even with the I tstat right?
so i still need
-I tstat
-eta harness and ecu and coding plug
-waterpump pully
-need to pick up the headers
also need to mount the alternator and ps pump, not sure if i have all the parts to mount them, it sucks because ive never worked on these before and i recieved the car with no motor in it and a trunk of parts lol.
yanked the motor back out and dropped the trans, damn these 260s are light!
sorry for the wierd color pics, for some reason my phone decided to not be normal lol.
managed to get the motor and trans mated and back in it goes
