Riced out the front calipers
Before:
After:
While that was drying I tackled the side "trim" on the car.
This stuff worked pretty well for helping me remove this crap.
Put some on the "trim" on my car and let it soak for a few. Used a screw driver to push out the "trim" from behind (used the holes meant for the clips to hold the stock trim in) and it came off.
The 'trim'
Removal left some sticky contact cement behind. Soaked with more 3M remover and then using my finger rolled it all off of the paint.
When I was done I was left with this:
I need to use some more of the remover or some bug and tar stuff to get at the crud that is left from the edges of where this old "trim" was.
Also you can see the body of the car likes to bend quite a bit when the front is jacked up, as you can see the door sticking out quite a bit at the bottom, it doesn't do that when it's down on all 4 wheels. Both doors are also hard to open when the front is jacked up.
Next going to see if I can clean up the proper molding I have for the car with some acetone. I've heard people have used that to prep the molding for trim paint but somehow the acetone works wonders on the molding and makes it look like new. So we'll see how that goes. Hopefully will get to that tonight and then I can install it and have a much better looking car.
Before:
After:
The 'trim'
