Little project today. As mentioned earlier, my in-tank low pressure pump broke. It's getting pretty hard to find working used ones, and new ones range from $150 to 250 depending on where you look.
To get me over at the last event I just eliminated it and let the HP pump work a bit harder. Seemed to work fine, but would still rather have it "like the factory wanted it" just to help the life of the HP pump.
This isn't "my" idea, apparently it's pretty popular in the e28 groups at least if not e30 groups, but the grassroots solution is RockAuto, of course. But not BMW parts - you get the in-tank LP (lifter) pump from a 1973-1976 Chevy Vega (and probably other GMs of that era, I'd guess). $15 new.
It's the right size, though doesn't have the bracket. Comes with a new in-tank pre-filter as well. To fit it up, you really just have to put some ring terminals on the original wires and they use small nut attachments to the pump.
One thing is the pump doesn't specify polarity of the terminals, so had to do a bench test to see which way was pumping fuel out vs. in. My 6-year-old helped me..
A couple hose clamps or zipties secure it to the original assembly, oriented to leave space for the fuel level sender
Anyhow, installed it and it seems to work fine. The HP pump's buzz seems substantially quieter now as well (though the buzz at all kind of annoys me since it's a pretty new Bosch pump). So, some peace of mind at very least.
