The complete repair, rebuild, repaint, and v8 swap of my early model sedan
  • JGood
    • Jan 2004
    • 7959
    #136
    Thanks man. I definitely have learned a lot. It's not so much that I can lay a perfect bead every time (far from it, actually), but I'm starting to be able tell when I'm not doing it correctly, and more importantly, know what to do to correct it.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • JGood
      • Jan 2004
      • 7959
      #137
      These guys showed up today:
      • Garageaholic
        Freestyle Fabricator
        • Dec 2005
        • 5204
        #138
        Holy shit Justin. Looks great. Looks like you're getting the hang of the welding. Do you have any idea when you plan to start the actual m60swap?
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        Instagram.com/garageaholic
        Youtube.com/garageaholic
          • 37825
          #139
          Love the wheels!
          Classic BMW Specialists
          Santa Clarita, CA
          www.BimmerHeads.com
          • Ninz30
            • Nov 2011
            • 245
            #140
            This is a serious build
            My 1991 325i Cabrio Build
            http://www.r3vlimited.com/board/showthread.php?t=227529
            • JGood
              • Jan 2004
              • 7959
              #141
              Thanks guys. Frank, there really is no "start date". Everything I've been doing so far has been done in anticipation of the new engine (cutting out brackets from the bay, welding DME firewall hole closed, removing the battery tray, removing the core support, etc...). I have began cleaning the engine, and as soon as the e34 V8 remote brake booster linkage parts that I ordered arrive, I'll begin trying to mount those in the bay as well. So i suppose the swap has already begun, but don't expect pics of the engine sitting in the car next week or anything, haha!
              Worked on the battery tray/firewall/wheel well junction today. I knew this was going to be a PITA, so I woke up early to tackle it and knock it out in one morning. This is what I was dealing with:
              I figured it would be best to remove the remaining part of the battery tray since it had rust all around it, and weld new metal in.
              After doing so, I realized this thing has the 3 mounting studs for the glovebox, which would be hard as hell to duplicate without causing binding in the glovebox movement, so I promptly welded this piece back in, lol. It was only surface rust, so I just cleaned it up, plug welded it at the factory spot welds, and the welded the seams. Probably just as good as using new metal.
              Everything cleaned up and welded together:
              I wish I could put my feelings into words to describe the work that was required in this next pic. Welding upside down, up under the dash area, thin sheet metal, upside down, with a huge helmet, at a ninety degree corner, and did I mention UPSIDE DOWN? This combination of things made this job impossible. There was no welding technique here. It was just... hold the gun somewhat close and squeeze the trigger for 3 minutes until the two panels are connected.
              Looking at the pics of the engine bay, that all looks pretty ugly. I'm going to grind some more of the welds down, and seam seal it all, so it shouldn't look so bad when it's finished and painted.
              • kts
                • Jun 2010
                • 753
                #142
                Impressed with all of the work you are doing. Nice welder and setup too. I'm still going back and forth with what to pick up for my own use.
                I feel you on the welding upside down in a tight area, my friend had to do a ton of that for our 2002 Lemons build and it did not look like fun. :(
                • JGood
                  • Jan 2004
                  • 7959
                  #143
                  Thanks man. Yeah, the welder seems to be working great for my purposes.
                  Welding upside down in itself is pretty hard. Welding upside down when your body is crammed and twisted up inside a car so tight that you can barely breathe, while trying to do a 90 degree butt weld of thin sheet metal, is just impossible, especially when you're inexperienced. It was ugly, to say the least. I used a good chunk of that 2lb spool of wire, LOL!
                  One thing I forgot to add earlier. Before I started repairing the rust, I noticed the frame rails were extremely flimsy after I removed the subframe and rad support. I was able to flex them up/down and side to side with one hand. I figured that was normal. Now that everything is all welded up, the holes are patched and panels are stitch welded, they don't budge... at all. I can't believe there wasn't serious alignment issues with this car. And it makes me scared to think there are cars like this on the road. If I would have been in an accident, this thing would have folded up like a tin can.
                  • 325ix
                    • Aug 2009
                    • 7783
                    #144
                    Welding upside down for me was never a problem, it took me a while to trust the metal and that it wasn't going to drip though.
                    I love what you are doing so far!
                    • freeride53
                      • 11972
                      #145
                      Dude you are fucking nuts. You deserve the member title beast mode.
                      1983 Peugeot 505 STI
                      1992 Volvo 240 Wagon
                      • JasonC
                        Site Manager
                        • 14451
                        #146
                        Man you're doing alot of work. Good job man!
                        1992 BMW 325iC
                        1978 Chevrolet Monte Carlo
                        • deutschman
                          • May 2008
                          • 5958
                          #147
                          Work looks great! Just remember that by grinding welds down you make them a lot weaker. The bead on top is a reinforcement and helps hold the weld together. Try to just smooth them out a bit.
                          • JGood
                            • Jan 2004
                            • 7959
                            #148
                            Thanks guys!
                            Yeah, I'm only trying to get rid of as much of the weld as I have to, in order to make it visually acceptable and be able to easily seam seal over it. It's easy to get carried away with a 4-1/2" grinder though haha
                            • JGood
                              • Jan 2004
                              • 7959
                              #149
                              For the first time in three months, she's standing on her own feet again :)
                              Finished up both the passenger front floorboard, and the drivers rear floorboard. Everything is covered with rust encapsulator and seam sealer. All of the rust repair I set out to do, is finished. There's a bit more in the trunk, but that's cake compared to what's already done.
                              Next major things to attack are the rear quarter panel and the rust on the rear passenger side wheel well (just three tiny spots). The quarter panel will probably take a while, and the help of a friend, as I'm not up to body work quite yet. In the meantime, I'm going to get the engine in the bay and get the mounts fabbed up, so when my brake booster and linkage arrives, I can begin mounting that and ensure I have enough clearance. I also need to work on the rad support, fab up some brackets to make it removable in the future.
                              Once the quarter panel is back on, I'll begin prepping the car to be resprayed. Hopefully by the time that's done, I'll also be done getting the remote booster set up in the engine bay, so I can paint the car and the bay at the same time. Once it's back from paint, I'll install the engine and put the car back together.
                              Goal deadline: End of June.
                              • JGood
                                • Jan 2004
                                • 7959
                                #150
                                Got the rad support mounted this morning. I just copied Garey's idea from the previous page of this thread. I think I'm going to weld a whole new tab at the upper points, as I'm not confident in the thin factory sheet metal tab.
                                The tabs that I welded on look kinda flimsy in the pics, but it's 14 gauge steel that actually runs the entire depth of the rad support, and are welded the hole way around.
                                The welder was putting up a fight with me. Turns out the wire was tangled on the spool and kept jamming. Hence the terrible looking welds. I'll grind them down and run another bead I think.
