The complete repair, rebuild, repaint, and v8 swap of my early model sedan
  • JGood
    • Jan 2004
    • 7959
    #706
    Started on the exhaust today. I'm really happy with the progress so far. I've got the front pieces tacked together, ready to make an x-pipe next.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • evandael
      • Oct 2009
      • 2881
      #707
      it's always fun to come and check on your build. i can't wait to see the exhaust fabbing complete!
      • JGood
        • Jan 2004
        • 7959
        #708
        Lots more progress today. I made an X-pipe, and welded the front parts of the exhaust together. This has been really enjoyable so far, I can't believe how miserable it was the first time around. I guess that's the difference between working on an unlimited time budget, vs. trying to have it done yesterday.
        • Jurt
          • Nov 2011
          • 347
          #709
          wow nice work! what muffler setup are you going to use?
          Feedback
          http://www.r3vlimited.com/board/showthread.php?t=270560
          • JGood
            • Jan 2004
            • 7959
            #710
            Just the same Maganflow 12468 2.5" dual in/out, which I was using before.
            • F34R
              sLaughter
              • 12390
              #711
              Gets better and better.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • JGood
                • Jan 2004
                • 7959
                #712
                Finished the exhaust. The car sounds so much better without leaking manifolds, and with the x-pipe. It's got much more of the expected deep v8 rumble. I took it for a 10 minute drive with the o2 sensors hooked up, to see if I finally put the issues to rest that have plagued the car from the start. The car didn't even try to stall at all, which is VERY good news, but I'm not getting my hopes up yet. It still hesitates for a second when getting on the gas after engine braking for a few seconds. I've also got a new engine code coming up, "ignition secondary monitor", which is strange. May be a flaky coil or boot, but I didn't touch any of them, and I've tested/replaced them all during previous troubleshooting. Or maybe the DME is finally throwing a code to hint at what the problem has been all along. Either way, I'll need to track the cause of that down.
                I can't say enough good things about the Boost Depot's male/female stainless v-band clamps. Very high quality pieces at an affordable price. I will never use another style exhaust clamp. Not even a normal v-band.
                The car and I aren't huge fans of cold weather, so back in the garage we go. I'll wait until a nicer day to put some miles on it and continue troubleshooting and working out the bugs.
                • F34R
                  sLaughter
                  • 12390
                  #713
                  Stunning, such hard work and clean finish. Cannot wait to see this car in person.
                  Current cars:
                  ~ '87 535
                  ~ '06 X5 4.8is
                  • Jean
                    • 18228
                    #714
                    Bad ass man!
                      • 37826
                      #715
                      Awesome work on that exhaust Justin! It's not too loud with no center muffler?
                      Classic BMW Specialists
                      Santa Clarita, CA
                      www.BimmerHeads.com
                      • JGood
                        • Jan 2004
                        • 7959
                        #716
                        Thanks! It's certainly not as quiet as a stock 540i, but I don't think it's too loud to the point where it's obnoxious or anything.
                        • PROLAZCO
                          • 180
                          #717
                          You should DEFINITELY post a video of the engine running with that new exhaust... I haven't drooled in a while so it would be nice to hear that beast.
                          Originally posted by whiltebeitel
                          Has anyone told you your car sounds like secks? Big, manly, hairy sex, that is. None of that wussy romantic "making love" crap, either.
                          • MattAvino
                            • Jan 2011
                            • 2147
                            #718
                            Originally posted by PROLAZCO
                            You should DEFINITELY post a video of the engine running with that new exhaust... I have drooled in a while so it would be nice to hear that beast.
                            This
                            E30 buildy things
                            http://www.r3vlimited.com/board/showthread.php?t=195286
                            • JGood
                              • Jan 2004
                              • 7959
                              #719
                              I reset the codes for the DME, and took it for a 10 minute drive.
                              Came back, and the following codes were already thrown:
                              19 - Ignition coil cyl 1
                              31 - Ignition coil cyl 2
                              32 - Ignition coil cyl 3
                              18 - Ignition coil cyl 4
                              34 - Ignition coil cyl 5
                              16 - Ignition coil cyl 7
                              33 - Ignition coil cyl 8
                              0f - Ignition secondary monitor
                              I find it odd that 7 of my 8 coil packs took a shit, as I didn't have any of those codes before removing and reinstalling the engine, and I didn't take anything apart on the actual engine itself. The engine isn't missing or stumbling. If I disconnect a coil pack, I can hear it start missing and running rough. Plug it back in, and it smooths out. So they are working.
                              And I have no idea what "ignition secondary monitor" means. I can't find any info on it anywhere.
                              I'm frustrated, to say the least.
                              • dirty30
                                • 3005
                                #720
                                Did you check your engine ground? Just a thought.
