Is it the width of the teeth that makes it progressive?
The complete repair, rebuild, repaint, and v8 swap of my early model sedan
Since the pinion is helically cut...
As the pinion rotates, the next pinion tooth engages the rack tooth at the "top" of the rack. As the pinion rotates, the contact moves from the top of the rack to the bottom of the rack.
The distance the rack moves as the same pinion tooth pushes on the rack tooth is greater for the more steeply angled teeth near the ends than it is for the shallower angles at the center.
Those are cool photos. Thanks for posting!
It looks like there are only 2-3 transition teeth and then after that the high angle teeth and rack speed are constant.Comment
I was considering that. I saw an article in the Roundel where they actually recommended that, before the tools/parts were available to replace the sleeves. But the sleeve has some sort of coating, I'm afraid I'll get it working nicely, put it all in the car, then have to pull it back out again 3k miles later. I literally have to tear my entire car apart to get the trans out :(
I found the parts, and the drift tool specs (they're simple, just 1" rods with stepped lips to hold the sleeves). I'm having a buddy make me the tools, so I think I'll give this a go.Comment
I've had the car back together and ready to drive for a couple weeks now. We've been getting a ton of bad weather so it's just been sitting. I did take it for a 5 mile drive Friday to test things out. I parked it after that for the weekend, and yesterday got under it to check for any leaks. Sure enough, it had a run of oil coming from the same spot, where the head/block/timing covers intersect. I can't imagine my new gasket/sealer didn't seal, so I'm thinking it's possibly the head gasket. It's really frustrating because I pulled the engine mainly just to fix this leak. I decided to throw a big glob of 'The Right Stuff' all over where it's leaking, just as a hail Mary. I am 99.9% sure that it will not do anything, and I will have to tear the engine apart. Really frustrating...
Here's a pic from before I tore it apart. Looks the same right now.
Looking at a pic of the head gasket.... You can see how thin the area around the oil drain is. And what the hell is that little metal-looking thing at the edge of the gasket? That looks like it's right where mine is leaking. How could the head possibly seal to that? I don't remember seeing that when I assembled the engine.
One of the things I wanted to do this winter was make a new set of engine mount arms. When I originally put the m60 in, I used 300mm.de mount arms. When I did the m60b44, I notched the oil pan, ditched the 20mm subframe spacers, and made my own mounts that lowered the engine 20mm. When I did this, I completely jacked up the alignment. Height wise, I was dead on, but the engine was shifted about 3/8" to the passenger side.
I fixed that by remaking the mounts. I put them on, and noticed right off the bat, the steering shaft is now kissing the header. When I originally modified the header, I curved it around the steering shaft, so when the engine was lowered, it no longer fit that curve. But the fact that I screwed up the mounts and pushed the engine to the passenger side gave it clearance, until now. There's no easy solution there, as much as I wanted there to be. So I removed the sway bar, control arm, steering rack, engine mount arm, and lifted the engine about 3", all so I could wrestle the header out after spending an hour getting the bolts off. There just isn't any room at all.
Once off, I notched it. Yes, this will theoretically impede flow. But one look inside the flange where it bolts to the cylinder head, and it's obvious this stamped steel piece of crap isn't exactly doing a great job from the start, so I'm hoping it won't be noticeable. I'll eventually do a set of custom headers.
I picked up the harbor freight fender-mount hoist thing. It's spectacular, I wish I would have bought one years ago. Worth every penny.
My guess is that rectangular metal contact thing ensures that the head is grounded to the block?
It is a fiber gasket right? so whatever is leaking will just make its way around the right stuff
I would think the head bolts would take care of that. That rectangular thing is very thin, and is only pressed/glued into the surface of the gasket, it doesn't go through it.
It is a fiber gasket.
I'm now investigating the possibility of excessive crankcase pressure, possibly only at high RPM's. I pulled the CCV off the intake manifold, and saw that the intake was covered in oil, and there was actually a small pool of oil at the bottom. This is generally caused by a torn CCV diaphragm, but mine was not torn or otherwise failed.
I verified that the OSV drain tube is not clogged. I didn't see any damage to the OSV that would cause it to not function properly. So there's no reason that I should have excessive crankcase pressure. I do have crankcase vacuum at idle and while revving the engine in the garage. But, for oil to get in the manifold, something is happening. And if it is excessive pressure, that would likely explain my leaks. Possibly only happening under load near redline?
I'm going to try to make a stable setup to check inches of water vacuum while driving. Should be interesting haha.Comment
Sorry didn't know how far to go back and check... but were the heads rebuilt? New valve stem seals/guides specifically? Ever get any smoke when you hit the throttle after idling for a long time? This might cause oil in your intake... though theoretically your CCV system should keep that from happening I think?
Reason I ask... is that I am experiencing this with my N62 in my e53. After idling for 10-20 mins I'll get a puff of smoke from the exhaust on take off. Going to do the stem seals, VC gaskets, upper (maybe lower too) TC gaskets, alternator bracket leak, coolant transfer pipe, valley pan, etc, etc... fun stuff."A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
87 325 Daily driver Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
92 325ic Sold & Re-purchased
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i SoldComment
Yeah, n62 valve seal failure is very common, leading to the smoking you're experiencing. That'll be a hell of a job for you haha.Sorry didn't know how far to go back and check... but were the heads rebuilt? New valve stem seals/guides specifically? Ever get any smoke when you hit the throttle after idling for a long time? This might cause oil in your intake... though theoretically your CCV system should keep that from happening I think?
My heads were not rebuilt, but oil in the intake can only come from the crankcase, not from any part of the cylinder head. Even if oil was getting into the combustion chamber through valve seals or piston rings, it won't go upstream, against airflow, into the intake manifold, it would just burn and smoke out the exhaust.Comment
Gotcha... I was thinking it might be contributing to the crank case pressure not necessarily contributing additional oil. At any rate... why not add a catch can to prevent the oil reaching the intake. I realize this does nothing for the head gasket leak... but it seems a common problem with the BMW V8's to be getting oil into the throttle body. I haven't opened mine up yet... but I wouldn't be shocked to see it in there.Yeah, n62 valve seal failure is very common, leading to the smoking you're experiencing. That'll be a hell of a job for you haha.
I am notoriously bad at remote diagnostics... lol I have to see and own a car to be any good at troubleshooting usually. And yes, I am dreading having to all that work on the X5. Ughhhhh... got a decent deal on it and it's such a good looking truck, but man everything is 10x harder and 5x more expensive than any of the 3 series chassis. It leaks oil from everywhere... and the dealer did one helluva job degreasing the engine before I saw it.
Edit: Just noticed you're in PA... BMW V8's seem to not like the cold at all because of the CCV system freezing/clogging. Have you done the entire system? I know on the m62 they added an electric heater wrap and updated the oil return tube because of this. If the CCV is stuck closed it causes excessive pressures... usually blowing out VC gaskets and oil seepage from filler cap. If it is stuck open it sucks oil into the intake possibly hydrolocking it. I'm new to BMW V8's (e53 X5 is my first) and I'm not loving the complexity of these things so far. The power and torque are fairly addictive though.Last edited by Schnitzer318is; 02-24-2015, 12:53 PM."A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
91 318is Turbo Sold
06 4.8is X5
06 Mtec X3
05 4.4i X5 Sold
90 325i Sold
97 328is Sold
01 323ci Sold
92 325i Sold
83 528e Totaled
98 328i Sold
93 325i SoldComment
Oh yeah, gotcha, that is definitely a possibility. I'm not sure to what extent the OSV/CCV is able to compensate for blow-by. The engine runs great and doesn't smoke. I haven't done a compression or leak down test, but I suppose it wouldn't hurt. I still want to do a water inches vacuum gauge to see if crank case pressure is even an issue. For all I know, it might actually be pulling correct vacuum.
The m60 OSV is internal, located right behind the timing chain on the block, whereas the e53 X5 m62 OSV's were external. So they don't experience the same cold weather issues, they stay at engine temp regardless of ambient temp. I had an m62 X5, got rid of it before it started to nickle and dime me to death. Amazing vehicle in every way, and I do miss it, just way too many expensive, failure prone parts on it. It would be hard to justify replacing a $3.5k trans in a $10k vehicle. Or a $2k timing guide/upper gasket overhaul, $1.5k coolant overhaul, etc... $200 window regulators breaking constantly gets old too.
But they are sexy!
