The complete repair, rebuild, repaint, and v8 swap of my early model sedan
  • JGood
    • Jan 2004
    • 7959
    #1081
    Originally posted by Shock(/\)ave
    Emphasis mine:
    You might be surprised to learn this, but your throttle pedal has an entire linear range of motion which allows you to input infinitely variable amounts of power, thereby giving you the ability to accelerate at a reasonable pace that won't keep breaking your damned car. :p
    I've never seen a more involved restoration project that resulted in more breakages than this one, especially given that it's a street car. It's enough to make any sane reader want to avoid huge increases in power. ;)
    Likewise, I can't even fathom putting years of blood, sweat, and tears into building a powerful car, and leaving it sit it the garage, or cruise around at part throttle, scared of what will happen if you use all of the torque you paid for.
    My goal was a car I can drive hard, reliably. I might not have gotten it right the first time around, but as things break, I learn, fix, modify, make stronger. It's fun (most of the time!)
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • The Dark Side of Will
      • Jun 2010
      • 2796
      #1082
      Originally posted by JGood
      Why not put the camber adjustment at the outer points and toe adjustment at the inners?
      BMW built a toe-adjustable subframe for the E34 M5 and put the toe adjusters at the inner pivots.
      Having the toe adjustment on the outer pivots means that the wheel will swing fore/aft by twice the amount of adjustment... this could cause problems if you're really tight on tire clearance... as you are.
      • kts
        • Jun 2010
        • 753
        #1083
        It absolutely would. It's on my to-do/to-buy list. There are many things on that list, far more than my car budget allows at the moment haha.
        I feel you. I'm hoping to save up for an M60 swap in my car but at this point that's ~4 years out since I have to many other things to pay for first.
        • Shock(/\)ave
          • 350
          #1084
          I agree completely.
          You're a madman. ;D
          • JGood
            • Jan 2004
            • 7959
            #1085
            So I put about 30 miles on the car and rechecked the suspension. I'm at exactly -1 degrees of camber on both sides, and the tires don't rub at all. I'm stoked. I wish I would have done this a long time ago.
            Night and day difference as far as traction. It hooks up in every gear. Even 1st, I can punch it and it just goes. The tires still make some noise and I can feel them slipping a bit, but it's 99% acceleration. Need to get back to the drag strip and finally hit the 12's that I've been 1/10 of a second away from.
            Oh, and while I've got some free time, this is mainly what I spent the past year working on, and why there weren't any updates on my car. My buddy brought his 87 s10 over to my garage, and we swapped in a 525hp LS3 crate engine, T56 magnum, and a shortened Ford 8.8 rear.
            • kts
              • Jun 2010
              • 753
              #1086
              Quite a project with that S10. My first car ever was an '84 S10 with a woefully underpowered 2.8L V6. I would have killed for the kind of power your friend's car is putting out now.
              • MR E30 325is
                • Dec 2008
                • 3299
                #1087
                Excellent Stuff!!
                My previous build (currently E30-less)
                http://www.r3vlimited.com/board/showthread.php?t=170390
                A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                • JGood
                  • Jan 2004
                  • 7959
                  #1088
                  Haha, yeah that's the motor we pulled out of it. This was his first vehicle too, bought it 16 years ago.
                  • JGood
                    • Jan 2004
                    • 7959
                    #1089
                    Couple updates:
                    My alternator died in a flaming, spark throwing, growling, spectacular fashion. I had to remove half of the car to replace it.
                    I also got a DUDMD tune that he made for the m60b44. It is based off of the e34 530i manual trans 404 DME tune (modified, obviously). This completely took away the hesitation and insanely loud exhaust cracking/popping coming off of decel fuel cut, and throttle hanging when lifting off the throttle. The power feels great, pretty sure it picked up a few HP from idle to redline. It also shoots flames when shifting above 6k, which is fun.
                    • Shock(/\)ave
                      • 350
                      #1090
                      Of course it did. ;D
                      Happy to see an update on the car man! It's been ages...
                      • Jean
                        • 18228
                        #1091
                        Dude, any thoughts on what happened with the alternator ? Internal failure ?
                        • JGood
                          • Jan 2004
                          • 7959
                          #1092
                          Bearings. I knew something in the accessory drive system was on it's way out, as I had a slight hum for a while. Then as I was leaving work, it started really grinding. Limped it 15 miles home, figured the worst that would happen is it would seize and I'd throw the belt. Popped the hood in my garage with the car running, and it's literally shooting sparks and flames from the vents in a spiral fashion. Lol
                          FYI, Rockauto has m60 Remy reman alternators for $83. I wouldn't be surprised if the Bosch reman units were rebuilt by Remy anyway, but the Bosch labeled units are $200+. I actually found several companies that sell all of the internal components for this alternator really cheap, and the rebuild process doesn't look hard at all. But I figured mine had been through hell so I might as well start fresh.
                          • wworm
                            • Dec 2016
                            • 1719
                            #1093
                            i just sank into this wormhole of a thread so deep that i ended up running out of time to go mount my new tires on my new wheels. Totally worth it. You're an inspiration haha.
                            1984 Delphin 318i 2 door
                            • JGood
                              • Jan 2004
                              • 7959
                              #1094
                              It's been a little while. If you've participated in this thread from the beginning, you know what that means. Bad shit/stupid shit happened, because that's what happens in this thread.
                              Driving home last Thursday at 10pm or so, doing about 65 on the highway, when all of a sudden it felt as though I was being launched in the air. That's because I was. I hit an 18 wheeler tire retread which I did not see. Son of a bitch. I don't have time for this shit at the moment.
                              Ripped my lip off, which I ran over, and bent/scratched the valance up. I believe that is all. That's actually not bad. Onto the repair, which was completed in about 48 hours. Like I said, I don't have time for this shit. Quick/cheap repair it is....
                              The damage: Lots of paint missing, and 2 bad cracks. Not bad, considering what it just went through.
                              Sanded the thing down, feathering out the edges:
                              Applied plastic bond to the cracks. I let this dry overnight with the lip on the car, so it would dry in it's home position:
                              Sanded down the plastic bond, sprayed and sanded some high build, then hit it with a spray can of single stage acrylic enamel I had the local body shop supply place mix up. The color matches great, the finish of a rattle can of single stage compared to the rest of the car, not so much. Oh well. It's a lip, and it cost me $40 to repair.
                              So I get this all finished, and decide to go for a drive. Out of nowhere, I hear a whine. Get it home, start doing some investigating. Remember the last time I posted in this thread? My alternator failed? Guess where that whine is coming from? Sure enough, check voltage, barely holding 12.1v at idle, and now the battery light is on. Son of a bitch.
                              • Reichart12
                                • Aug 2012
                                • 2150
                                #1095
                                It wouldn't be a fun e30 if everything went smoothly?
                                Lip repair looks good though.
                                Instagram: Reichart12
