Originally posted by csermonet47
View Post
Kamotors E30-Turbo to ITB M20
I ran outside in the cold and made a quick video(yes I'm killing the starter but I needed to make a video of it trying to start.
I'm having to almost floor the pedal to even get the car to pop. and once it starts it takes almost half throttle to keep running.
http://www.youtube.com/watch?v=wTtx_...&feature=g-uplLast edited by kamotors; 12-03-2011, 07:11 PM.
7speedshop.com
Originally posted by BUDNUNTA View Postput the stock injectors in there and try it, just to get it running,
im not familiar with the war chip but maybe bypass that too,
see if it will run essentially stock
It ran a few weeks ago on the stock injectors and this same tune. It really seems that the injectors are too big even though they are the recommended injectors.
7speedshop.com
Originally posted by CorvallisBMW View PostAutos don't 'blow up', they just loose their clutch packs and slip to the point of being un-driveable :) But still, it will be entertaining to see that comes of it. I give it 5000 miles, tops.
Originally posted by JeremyE30autox View PostIf you don't mind me asking. Where did you pick up the turbo?Originally posted by kamotors View PostEbay for $150:)
other than ebay manifolds, they cost a lot.
What injectors are you going for now?
and do u still have stock fuel pump? maybe walbro 255 is needed. i read everything just now but i may have missed something.
btw how do u know which coil to buy? the only part im confused on is spark for my turbo? did u upgrade to the 8mm spark wires or are the the stock 7mmm20 is plenty. im simply a drifter.
build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
ooor could it be the MAF?
i did a quick ebay search for M20 maf's but only AFM's came up. cause u had the Miller MAF there for the first start up I think. Now that the WAR chip doesnt have its MAF there its still running for its dimensions. email miller and send em your map and i think they will straighten it out
GLm20 is plenty. im simply a drifter.
Originally posted by KI4UJO View PostI would not go that far. My dad had an 85 camaro w/ a very torquey 350 from an RV. The 700R4 got its output shaft ripped out I believe. This was newly rebuilt as well. OP, nice build.
