Kamotors E30-Turbo to ITB M20
  • cleanasse30
    • Jan 2014
    • 436
    #3136
    That sounds great!
    2.7i Stroker Turbo Build Thread
    90 325i | 95 Miata
    • efficient
      • Feb 2012
      • 3312
      #3137
      Sounds and looks like a blast to drive.
      • e30 power
        • Mar 2006
        • 413
        #3138
        awesome job on this car, i was reading thru and you said the 6262 precision turbo its not very good for autox? so I'm asuming a drift car falls in the bad... what turbo do you/all think is the most suitable turbo for a drift car? i did the rxh6 turbo i get full boost at 3700. debating if i should switch turbo
        8)8)
        • cleanasse30
          • Jan 2014
          • 436
          #3139
          I have a BW/AGP S256SX with a .64 A/R turbine housing and I'm seeing 10lbs in the low 3k range. So far I love my turbo even with the low boost, it should really come alive with 14lbs where its in better efficiency islands on the compressor map.
          90 325i | 95 Miata
          • IronFreak
            • Dec 2012
            • 3702
            #3140
            Net even sure how you can compare drifting with auto-x.....not remotely the same thing.
            Instagram @rebellionforge
            • e30onBBSs
              • Dec 2014
              • 1347
              #3141
              Port the intake mani for some weight reduction and moar powaaa? ;D
              BMW tech
              Umass Amherst
              05 wrx sti
              • kamotors
                • Nov 2007
                • 7102
                #3142
                Sent from my SM-N900T using Tapatalk
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  #3143
                  boost at 10.5psi (+- a bit) pulling strong, need to close up spark plug gap some more as its getting an untunable rich spot after 6k that seems like spark blowout.
                  7speedshop.com
                  • Bimmer_man
                    • Jan 2013
                    • 1478
                    #3144
                    nothing to see here. Law abiding citizen just getting some fuel
                    Float like a cadillac sting like a Bimmer!:)
                    • e30 power
                      • Mar 2006
                      • 413
                      #3145
                      i agree not really comparing auto x and drifting but was throwing examples to give an idea of what i was asking... sorry for the dumb exampling lol
                      8)8)
                      • e30 power
                        • Mar 2006
                        • 413
                        #3146
                        love the build kamotors awesome work
                        8)8)
                        • sayed ali
                          • 762
                          #3147
                          Awesome video! Probably @1Bar of boost it'll be beast :)
                          M20B28 Turbo
                          My Build Thread
                          http://www.r3vlimited.com/board/showthread.php?t=255839
                          • kamotors
                            • Nov 2007
                            • 7102
                            #3148
                            yup but I'm afraid I'll need a new clutch at that point, it may be hard to believe but I'm on a new sachs clutch and its holding a surprising amount of power and abuse.
                            7speedshop.com
                            • cleanasse30
                              • Jan 2014
                              • 436
                              #3149
                              If you're looking for a new disc and want to maintain a stock-ish feel I would recommend the Clutch Masters FX-400 8-puck clutch. Pedal feel is virtually the same as stock in terms of weight, but the clutch is slightly grabbier.
                              I'm at 10lbs right now and it hasn't shown any signs of slipping. Hoping to turn it up to 14-15lbs in the next few months.
                              90 325i | 95 Miata
                              • IronFreak
                                • Dec 2012
                                • 3702
                                #3150
                                QuarterMaster triple disc ftw.
