Looking great there :) do you still have my number? I'm still on the hunt for a steering wheel! I'm on a slow down due to school coming up and needing to save funds though, so I'll be working with what I've got now. In for more pics too :D
Alpina B6 3.5 Turbo Tribute
Thanks, Kelly.
If you had contacted me sooner with a text. You could of bid on this.
DSC04926 by Raul Salinas, on Flickr
DSC03413 by Raul Salinas, on Flickr
I was planning to solder the wire on fuse. I decided to not do it. Thats why I went to the junk yard to score me some a other small fuse box with wiring.
Before
DSC04297 by Raul Salinas, on Flickr
After with cap.
DSC04310 by Raul Salinas, on Flickr
DSC04311 by Raul Salinas, on Flickr
I found out I need early cruise control switch bracket and maybe cruise control switch.
Here is a pic out of my 88 e30 m3 cruise control bracket.
DSC04320 by Raul Salinas, on Flickr
While I am waiting on those parts. I started to test head light wiper system motors. The two on my car would not move with power on. Those came from Ireland UK. Later I will pull the covers on motors to the problem. I had the other set from the ix head light wiper system. Test the ix motors. The ix motors turned on.Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Yes! I didn't see any good chrome trim in the junk yard.
Here is a pic of a rusted motor.
DSC04322 by Raul Salinas, on Flickr
These ix motors work. I was happy they did.
DSC04321 by Raul Salinas, on Flickr
I went back to junk yard on Saturday to cut wires off early e30. I found a euro e28 520i in the yard. I took some wires like rear fog light wires and a other plug wire for wiper system.
DSC04325 by Raul Salinas, on Flickr
DSC04326 by Raul Salinas, on Flickr
Looks like I need to go back to the junk yard for fuse box connections for head light wiper system relay.
DSC04333 by Raul Salinas, on Flickr
DSC04334 by Raul Salinas, on Flickr
I did get the cruise control bracket and installed it. The only thing i need to figure out is where to plug into cluster.
DSC04354 by Raul Salinas, on Flickr
I went to the shop to study the wire in fuse box and under the dash on my 1985 euro 320i. I figured what color wires I needed to add to fuse box. I need 2 brown and white wires. The other wire is brown and blue. The brown/white and brown/blue go to connector to stalk.
The other brown /white wire goes to head light switch knob for power.
DSC04356 by Raul Salinas, on Flickr
DSC04361 by Raul Salinas, on Flickr
This Saturday I found a 1985 e24 635i. It had the fuse box that came with wires I was looking for
DSC04357 by Raul Salinas, on Flickr
hi Raul
late to the party here, but let me know if you need any help with the headlamp washers. my HLWS setup is working well, except for the intense clean circuit - have swapped relays and modules, but can't get the intense clean pump to turn on.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
e30m3s54turbo: I save my money for tuner parts.Comment
the pins are still available new. very easy to retrofit.Looks like I need to go back to the junk yard for fuse box connections for head light wiper system relay.
some hlws links and info hereI BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Thanks, Brad for the link.
I was able use pins and the right color wires off the e24. The wires were the same as my euro 320i.
I was to lazy to order pins from dealer. I did find a euro e28 520i in the wrecking yard. It was stripped of parts. I cut some wiring off it.
I might need your help on head light adjusters?Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
glad you sorted it out. pretty exciting to get all that stuff working. Japandrew was the hlws pioneer, but all his pics are gone as you know.. took me quite a while to figure the install out. still chasing a wiring issue with the intense clean pump.Thanks, Brad for the link.
I have the switch and cables, but not the wiring and actual adjusters unfortunately. Happy to research things with you.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
I also have switch,plastic tubes and adjusters. I'm thinking of ordering two new sets from Germany. I might contact screen name Longwolf from France. I will ask him again how much he bought his kit for.glad you sorted it out. pretty exciting to get all that stuff working. Japandrew was the hlws pioneer, but all his pics are gone as you know.. took me quite a while to figure the install out. still chasing a wiring issue with the intense clean pump.
I'm 99% sure all euro e30 have perversion for plug and play like head light wiper system, rear fogs and head light adjusters. I know my US e30 have no wiring and pins. The US in the 80's didn't allow BMW to add those parts.
I spent about two hour on Saturday studding how BMW wired it up and color codes. I did text Japandrew for info and pics. He did not have pics. He could not remember where wired his black wires.
The only difference between stock head light wiper system IX e30 is the water bottles and the wire harness is longer to reach the batterie tray. The is a other plug on diver side for water bottle. I think the IX and the m21 turbo desiel share the wire harness. On the m21 desiel use the intensive reservoir on diver side next to where m20 air box would be.
I have few sets of head light smilies with adjuster brackets. I think my adjusters don't look like they will work.
Any links or info on this would be awesome.Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
I am still working on head light wiper system.
I trying to figure out why Hids head light will not turn on.
I finally was able to find and buy a front real Alpina B6 3.5 badge for a e30.
Here is a B6 3.5. Notice the 3.5 is paint gold. Alpina doesn't offer the front any more. Just the rear.
DSC04388 by Raul Salinas, on Flickr
Here is a pic next to Alpina B63.5s e30 m3. Notice the 3.5 is in silver.
DSC04382 by Raul Salinas, on Flickr
DSC04384 by Raul Salinas, on Flickr
DSC04378 by Raul Salinas, on Flickr
Glad to see you got the badge finally.Comment
