I thought the e36 coolant temp sensor for the ecu was blue... (closest to radiator)?
My e30 24v project, 90
hmmm not sure what color it was supposed to be, just know that the one in the front hole was originally there, the one in the rear hole is the m20 sensor i installed.sigpicFellow e30 enthusiast
Dont waste your time hating, aint nobody got time fo dat
1986 bronzit 325es- SOLD
1987 delphin 325i- parts car
1990 scwarz 325is- m50 drift slut
CHECK OUT THE BUILD!
http://www.r3vlimited.com/board/showthread.php?t=229234
You want to use the brown sensor from the M20 for the swap. Twists right into the rearward sensor spot on the head.‘Tis by the grace of God that my cars run!Originally posted by LJ851kingston is the play by play announcer for this thread.
Siobhan's Build Thread - UPDATED!Originally posted by unloadedak#teamross
yeah thats the one thats in there, but is the front sensor thats still in the factory spot supposed to stay there? or be a different sensorsigpicFellow e30 enthusiast
maybe its a cheap aftermarket sensor? not color coded? it was in the motor when i got it from a 1995 325i m50tu auto.sigpicFellow e30 enthusiast
Im getting so pissed of waiting for shipping on my ECU it was supposed to be in on friday, on friday it was in kentucky, im in RI, it went to puerto rico, way out of the way for no reason. also eagerly waiting my harness from markertmotorworks and harness coverssigpicFellow e30 enthusiast
it is close, but evidently this shits not really in america thats why i cant find any info on itsigpicFellow e30 enthusiast
i found a few other cars with the exact kitsigpicFellow e30 enthusiast
Got my harness conversion from dave @ markert motor works today, along with the harness covers and the dust shield that goes behind the flywheel, and a set of knock sensors. If all goes as planned the swap should be in the car saturday!sigpicFellow e30 enthusiast
If the coolant temp sender thing is still a problem, it should work as long as their is one prong. the one i used is black with one prong and it works fine.1985 325e M50TU(Sold)
1991 318is Slicktop (Sold)
1990 325is Brilliantrot S50/5 Lug Swapped.
1992 525i Manual shitbox Winter BeaterComment
Not trying to jack the thread but is this coolant temp sensor applicable to M50 NV swaps as well?Comment
yeah, its just the temperature sending unit for the instrument cluster. you can take it out of your factory m20, the brown one. i just ordered one for my car 90 325is and it was like 20 bucks maybe.sigpicFellow e30 enthusiast
