Where is your upholstery guy located? Sorry if I missed it I only ready parts of thread. Btw awesome car!
2nd E30 - Project MTechnik 1 S52 Convertible
PM sent.- Frank
'87 325ic M-Tech 1 For Sale!
http://r3vlimited.com/board/showthread.php?t=407503
Build Thread http://www.r3vlimited.com/board/showthread.php?t=229347
wow this makes me want to finish my tech 1 vert....
How did I miss this!
Really nice!
Glad you finally got the sideskirts, took me almost 2 years to find the vert ones too...sigpic
1986 "C2 2.7 Alpina" Sedan
1987 325ic Black Vert
Originally posted by Luis325 View Postwow this makes me want to finish my tech 1 vert....
Really nice!
Thanks for the kind words.- Frank
Helpful update (stolen from Levent's fb feed). Cmon Frank spill the beans on those wheels.. did you sell the Azevs?
and what's the deal with the headlamp wipers? they're almost opposite the position they should be. see this pic
Same here - the wipers are in the opposite position they should be - detail from an earlier pic of yours:
Your car's perfect bro. not criticizing - just helping you get it more perfect.Last edited by bradnic; 10-15-2013, 12:01 PM.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
DB vert plastic bumpers
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Borbet Bs 16x7.5 / 9
215/45/16 square
I found the original Center Caps on eBay Germany from a existing Borbet.de employee who sold them to me at an obscene price with never before installed Borbet logos (still had original adhesive backings)!!!!
I still have the Azevs, they are listed for sale but I still kind of like them and not in a rush to sell - may end up refinishing them unless the right buyer comes around!
I have the wipers on for show at the moment, I also have a set of rings that need to be re-done/powdercoated and I have motors, still searching for the electronics.- Frank
I still have a small laundry list of details I still need to work on:
- repair e-brake
- rear subframe bushings
- r/r all swaybar bushings
- wire up my high beams
Hopefully I'll put that altogether for next year.- Frank
Gotcha. On the wipers just loosen the nut and reposition per the pic.. Then no nosy questions :-)
Levent's got all the connector hardware you need for the smileys. But you probably know that :-) Make sure you replace the adjuster screws (8 of them) and plastic/rubber retainers too (12 of them).
I've got 2 E30s waiting on parking brake cables too. Heat and PB blaster. right next to the gas tank though. so lotsa blankets/insulation around the cable opening I guess.
Still trying to talk my wife into those Azevs, so if you're not in a hurry..I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Originally posted by bradnic View PostGotcha. On the wipers just loosen the nut and reposition per the pic.. Then no nosy questions :-)
Have a few more items on my electrical to-do list though:
1.) high beams
2.) einstein57/GE keyless entry kit w/discontinued e46 style keys!
3.) headlight wipers
4.) one-touch down all windows (4 in vert)- Frank
here's my wiper setup
everything's working except the intensive windshield clean stuff - still plumbing and wiring that up.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Originally posted by achtunge30 View Poststill searching for the electronics.
and the intensive wash wiper relay 61311369829 is $170
do you have the harness? If not it's NLA but quite simple - it wouldn't be hard to make one. You also need to make some fuse box and steering mods for the windshield intensive cleaning function:
- swap out the K10 wiper relay for the HCS relay with 2 extra pins.
- add 2 pins with wires to your fusebox for the PS and TS pins
- pick up the intensive washing wiper stalk (with an "S" button and 2 extra wires). there are 2 versions of this stalk, one for airbag 61311377974 and one without which is longer 61311372583 (still available, $156)
realoem info for headlamp cleaning
diagram 1
diagram 2
control relays diagram
steering column switches diagram
For docs there's the Japandrew HCS DIY but it's really wordy and missing all the pics.
He also has a link to the OEM installation manual
and there is a good HCS troubleshooting article in PDF form at e30zone
Hope this helps.Last edited by bradnic; 10-15-2013, 09:48 PM.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
If you look at post #70 you will see he changed out to the Type B. and wiper blades move, if they do not have a reset position. I would assume they just sit where they turned off.~ Puch Cafe. ~ Do business? feedback ~ Check out my leather company ~
Instagram: @BWeissLeather
Current cars:
~ '87 325 M30B35 swap
~ '87 535
~ 01 540 Msport 6spd
~ '06 X5 4.8is
Originally posted by F34R View PostIf you look at post #70 you will see he changed out to the Type B. and wiper blades move, if they do not have a reset position. I would assume they just sit where they turned off.Originally posted by achtunge30 View PostI have the wipers on for show at the moment, I also have a set of rings that need to be re-done/powdercoated and I have motors, still searching for the electronics.I BUY/SELL REFURBISHED CM5907s & CM5908s
HOWTOs:
OEM Keys
MTech1 docs
88 ix Lach/Card
91 ic Calypso 3.1
86 Cosmo 2.7
OEM+ or bust!
Originally posted by 5ickride View PostGlad you found the Borbet caps! They look great, how do you like the wheels overall? How do they feel on the road?- Frank
