91' 318is S52 Swap "The Beast"
  • bubbajan21
    • 1962
    #331
    Originally posted by cjdontthink
    Well I messed up again :(
    I messed up the front timing cover and crank seal
    Out of stupidity I put the bolts back in the harmonic balancer without compensating for the space of the pulley I'm not using in front of it.
    So the bolts were making contact with the cover and I cranked the engine by hand a few times and it tore it up quite badly :(
    What got torn up?? Is this because you removed the A/C pulley and used the same bolts? I took my a/c pulley off and put the same bolts back in and I have had no issues.
    • craiggroves91
      • Oct 2009
      • 3024
      #332
      Yeah, thats what happened :( The Timing case cover got scraped up quite a bit along with the front crank seal. I'm afraid it will leak now
      Thats odd maybe mine aren't the stock bolts? Regardless, it happened and now I need to fix it ahh
      1989 BMW 325i SOLD
      1998 BMW Estoril Blue e36 M3/4/5 SOLD
      1987 BMW 325 (The Piece) SOLD
      1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
      • craiggroves91
        • Oct 2009
        • 3024
        #333
        Big update!
        Doing the oil pan swap
        Taking off the old one
        Windage tray off
        Bye
        Cut bracket for s52 oil pickup tube. I cleaned it up further after this with a file
        Safety wired and red loctited the oil pump nut. The sucker was still on there pretty tight when i took it off. Wasn't going anywhere
        m50 pickup tube with new gasket
        Pickup tube and oil pump nut looking tidy
        Oil pan on with new gasket
        In the process of cleaning up the ZF
        New friction plate and e34 m5 stage 2 clutch kit on
        New pilot bearing, also did the rear main seal and rear main seal housing gasket
        Bolting up the trans with my dad and friends. New clutch slave and throwout bearing included
        All bolted up with redline MT90
        Waiting for some help to come by then its going in
        Poly and UHMW for days
        Help arrives. The mounts were a pain. Had to use the slots on the subframe and the bottom nuts were hard to get to because my reinforcement plates blocked access. should be good though
        Condor Speed shop UHMW mounts
        UHMW PS delete and mount
        Got the AKG quickshifter 2 in. don't mind the hairy persian friend
        1989 BMW 325i SOLD
        • mtlbloodshot
          • Jul 2011
          • 761
          #334
          I can't wait to see my engine in my bay. Great work
          MY BUILD THREAD
          http://www.r3vlimited.com/board/showthread.php?t=235231
          INSTAGRAM : @luchcolaneri
          • craiggroves91
            • Oct 2009
            • 3024
            #335
            I can't wait to hear it running!!!
            Good luck getting your engine in
            1989 BMW 325i SOLD
            • Cabriolet
              • 9620
              #336
              [/URL]
              This thread delivers. and i'm not looking at the dildo in the room.
              Much wow
              I hate 4 doors
              • Pantless Spency
                It's McRib time!!!
                • Feb 2011
                • 7284
                #337
                sorry for my lack of knowledge,
                but is that a sequential shifter?
                whatever it is looks hardcore.
                • craiggroves91
                  • Oct 2009
                  • 3024
                  #338
                  It's UHMW and poly mounts so she vibrates for ya!
                  No, my man. Its just a DTM style shift lever. Its quite high by the steering wheel where you want it. It has a really short throw and it bolts up directly to the trans tunnel, so it eliminates the carrier and all the bushing related to that. So I dont have to worry about anything wearing out
                  1989 BMW 325i SOLD
                  • craiggroves91
                    • Oct 2009
                    • 3024
                    #339
                    Been getting what I can done here and there. I finally got my DD 325e running again :) so thats a big relief
                    Worked on trying to get the harness on the firewall as clean as I can, still not finished yet. Have to do a little more work to get the m42 cover on. I liked how I got the obd2 diag port by the fuse box.
                    Got the relays on the m42 harness cover, they take up a lot of room in there though
                    Getting there
                    All zip tied up
                    I'll finish that up later
                    Also got the new e34 m50 throttle cable on, this was tough because of the relocated brake booster. I got it eventually, should have installed before I put the brake booster on. oh well
                    Also got the serpentine belt on
                    and rethreaded the e30 brown top coolant sensor to thread into the s52 head
                    Then I worked on cooling hoses. I was able to use all s52 e36 m3 hoses. I was able to cut up the long s52 e36 m3 hose that comes off the metal pipe and use it to make my heater core hoses and coolant reservoir to metal pipe hose. Top and bottom rad hoses are original s52 hoses, bottom had to be cut
                    Mishimoto aluminum radiator. All that was needed to make this fit was the drivers side rad mount from a late model 325i
                    Just have to hose clamp them all up
                    This one doesn't kink as much as it looks in the picture, might cut it some more
                    Mounted the Walbro high pressure fuel pump to the 318is frame and got it installed
                    1989 BMW 325i SOLD
                    • mtlbloodshot
                      • Jul 2011
                      • 761
                      #340
                      Very nice update, you've made great progress. Quick question, did you use the throttle cable bracket? It wraps around the cable and then bolts on the drive side shock tower. Did you reuse that?
                      MY BUILD THREAD
                      • craiggroves91
                        • Oct 2009
                        • 3024
                        #341
                        I was going to try to. I don't think its necessary. I wanted to see how it would route with the throttle body on before I install it.
                        1989 BMW 325i SOLD
                        • mtlbloodshot
                          • Jul 2011
                          • 761
                          #342
                          Ahhh okay okay.. Lemme know asap.. I need to know before I start closing up the holes in my bay.
                          MY BUILD THREAD
                          • craiggroves91
                            • Oct 2009
                            • 3024
                            #343
                            I wouldn't close up anything of the strut tower, unless you are welding. If you are using bondo it might crack.
                            1989 BMW 325i SOLD
                            • craiggroves91
                              • Oct 2009
                              • 3024
                              #344
                              Got the coolant hoses all hoseclamped today and worked on the m50 manifold conversion
                              Not sure if I mentioned this, but my s52 came with a Dinan throttle body.
                              1989 BMW 325i SOLD
                              • mtlbloodshot
                                • Jul 2011
                                • 761
                                #345
                                Of course im welding. Cant wait for you to see my bay ;)
                                Let me know for that throttle cable bud
                                MY BUILD THREAD
