91' 318is S52 Swap "The Beast"
  • Thrizzle
    • Aug 2011
    • 194
    #526
    Correct.
    It's been a while so I don't remember exactly what was going on, but I definitely had the clevis a slot over from where it should have been. Worth checking out.
    • craiggroves91
      • Oct 2009
      • 3024
      #527
      Originally posted by Thrizzle
      Correct.
      I know what you're talking about. Mine is in the right spot, sadly its something else :(
      thanks for the idea though
      1989 BMW 325i SOLD
      1998 BMW Estoril Blue e36 M3/4/5 SOLD
      1987 BMW 325 (The Piece) SOLD
      1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
      • whodwho
        • Jun 2008
        • 1547
        #528
        Originally posted by cjdontthink
        Thats what I'm thinking too!
        They are locked up slightly then when I drive they warm up and lock worse and worse.
        I'm going to play with it when it clears up outside
        This is exactly the symptom of when misadjusted.
        Lift the car and check each wheel spins without much brake drag. If one wheel has issue could be the caliper or collapsed brake line, if all of them drag then make sure there is free play in the rod or just back it off some and see if it helps.
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
        • craiggroves91
          • Oct 2009
          • 3024
          #529
          I've adjusted it every way possible. I mean I could be rushing it and not hitting the sweet spot, but I've pretty much tried everything with the pedal adjustment.
          1989 BMW 325i SOLD
          • craiggroves91
            • Oct 2009
            • 3024
            #530
            My pedal is adjusted to pretty much exactly Bentley's measurements. They are still rubbing and the master isn't even fully on.
            I think I found the issue. When I first removed my booster I remember the rod came out of place, I think when I reinstalled it maybe rod wasn't seated in the right spot?
            Again another EDIT: I think this little rod is the problem. Its not seating correctly and I'm not 100% sure why.
            I'm tempted to just grind it down and shorten it.
            I managed to snap a picture of the inside of the booster and the spot where this seats is worn, I think thats causing it to not seat correctly and flat
            You can see it looks like the rod was kinked down and me pressing the brakes caused it to wear.
            1989 BMW 325i SOLD
            • craiggroves91
              • Oct 2009
              • 3024
              #531
              So out of desperation and frustration I ground the rod down a couple millimeters and BAM! Brakes are golden, no more locking up.
              I don't see any harm in shortening the rod.
              I'm not sure how permanent this will be, but I just need the car drive able so I can go get smog.
              1989 BMW 325i SOLD
              • craiggroves91
                • Oct 2009
                • 3024
                #532
                And she's smogged ladies and gentlemen
                1989 BMW 325i SOLD
                • craiggroves91
                  • Oct 2009
                  • 3024
                  #533
                  So one thing I overlooked was the instrument cluster coding plug! My RPMs have been off this whole time. Luckily my buddy had one laying around and we put it in and its all good now.
                  No wonder I was disappointed when I punched it at 4k rpm!
                  1989 BMW 325i SOLD
                  • mtlbloodshot
                    • Jul 2011
                    • 761
                    #534
                    congrads on getting the brakes figured out now rape that shit :)
                    MY BUILD THREAD
                    http://www.r3vlimited.com/board/showthread.php?t=235231
                    INSTAGRAM : @luchcolaneri
                    • craiggroves91
                      • Oct 2009
                      • 3024
                      #535
                      They are still weird, but they don't lock up.
                      I'll rape it after I register it !
                      1989 BMW 325i SOLD
                      • ZekeTheSneak
                        • 1562
                        #536
                        Exhaust clips! I want to hear it moving. I'm so excited for my swap
                        • craiggroves91
                          • Oct 2009
                          • 3024
                          #537
                          Soon buddy! I haven't registered her yet!
                          1989 BMW 325i SOLD
                          • MR E30 325is
                            • Dec 2008
                            • 3300
                            #538
                            Well get on that! haha
                            Once again, excellent work.
                            My previous build (currently E30-less)
                            http://www.r3vlimited.com/board/showthread.php?t=170390
                            A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                            • craiggroves91
                              • Oct 2009
                              • 3024
                              #539
                              How did I not update this?! I've registered her and been driving her.
                              It's been a lot of fun and has been working great so far. I really need to swap the brake booster though!
                              1989 BMW 325i SOLD
                              • benyen soljax
                                • Mar 2012
                                • 290
                                #540
                                Blowing it.
                                Project 325is
                                Transaction Feedback
