Thread the clevis so that you have some play in the brake pedal. I know you say "I don't know how its supposed to feel" but just try it and see if it works.
91' 318is S52 Swap "The Beast"
Last edited by craiggroves91; 12-17-2012, 03:12 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
1998 BMW Estoril Blue e36 M3/4/5 SOLD
1987 BMW 325 (The Piece) SOLD
1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207Comment
Thats what I'm thinking too!
They are locked up slightly then when I drive they warm up and lock worse and worse.
I'm going to play with it when it clears up outsideYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
Ohh just letting to you know, I cut off that little black box in the bay.Comment
1989 BMW 325i SOLD
OKAY! so its pretty much most definitely something with the linkage, whether its the pedal adjustment, something installed wrong, something missing, etc.
I know this because I unbolted the MC nuts and slowly the brakes started freeing up and bam I can push the car with my pinky!!!
I'm going to try to adjust the pedal with the MC off to try to see when the rod is pushing and isn't pushing. If that makes sense. I'll let you know how that goes.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
Something is definitely not right and I have no idea what it is.
It seems like the booster needs washers on its studs to space it out.
the only time they are remotely freed up is when I screw the rod all the way into the pedal and even then they stick a little. The pedal is closer to the firewall then the gas pedal.
This makes no sense cause everything is factory and should be there.
Maybe something is missing where the rod pushed on the master? Everything seems to be thereYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
Awesome thread. Wish I could help with the brake issue, but I just got my e30 the other day :/Comment
I don't know if you need this or if it has anything to do with your problem, but I used this when setting up my E30 clevis on a AUDI A4 booster.
1989 BMW 325i SOLD
1989 BMW 325i SOLD
It sounds like your pushrod isn't lined up.
When doing my install I accidentally clipped the pushrod onto the wrong side of the pedal arm. It was weird because it looked like it was meant to be there. Anyway just a thought, get in there and check it out.Comment
You mean the clevis and pin on the pedal might be in the wrong spot?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
1989 BMW 325i SOLD
