91' 318is S52 Swap "The Beast"
  • 2mAn
    SeƱior Mod
    • 20242
    #691
    Glad to see it getting reincarnated
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • craiggroves91
      • Oct 2009
      • 3024
      #692
      I can't wait to drive an s52 e30 again. This prius my sister loaned me is killing me, but I love the efficiency.
      How do people mount the 325i expansion tank in a 318is bay usually?
      In the alpine car I welded the bracket on from the 325i, so I may do that again and just spray the welds with some spray paint. It's not visible.
      Sent from my SM-N920V using Tapatalk
      1989 BMW 325i SOLD
      1998 BMW Estoril Blue e36 M3/4/5 SOLD
      1987 BMW 325 (The Piece) SOLD
      1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
      • pandaboo911
        • 2070
        #693
        I used the plastic clip piece, without the metal bracket, worked fine. Moved it to the battery tray since it fits better there
        • craiggroves91
          • Oct 2009
          • 3024
          #694
          Bye bye beast. You will be missed, but Brilliantrot has me feeling some type of way.
          So I had to grab a lot of parts from the beast, including its front subframe. So pulled the m42 and its front subframe and stock suspension to swap with the beast. Here are some pics of that
          Pressure washed the BAE
          Subframe and suspension dropped
          Dropped the steering column to put in the pedal box from the beast that was welded when it broke a little while back. I figure it is much stronger and it will prevent the same breakage from happening to the stock pedal box.
          I've done more since then, but need to take pics still. I am awaiting some important parts, too.
          Pumped to get my coilovers on, but I don't have the correct strut not from vorshlag. So hopefully I can get that sorted out.
          1989 BMW 325i SOLD
          • craiggroves91
            • Oct 2009
            • 3024
            #695
            Subframe bushings are seized on the chassis arghhhh :down:
            1989 BMW 325i SOLD
            • craiggroves91
              • Oct 2009
              • 3024
              #696
              Success. Rebar vs an extension helped. Also helped to have my dad beat it while I heated it with torch.
              1989 BMW 325i SOLD
              • craiggroves91
                • Oct 2009
                • 3024
                #697
                Just some adventures of the day
                Burned out the subframe bushings
                Painted the brake line holders brackets or whatever just to tidy things up. I also painted the custom coupler nut for my swaybar should I made from e36 m3 endlinks
                Test fit the struts with the e36 m3 swaybar tabs welded on and the end links I made. Seems like it will work great. I'll know more when it's on the ground.
                1989 BMW 325i SOLD
                • TheWipprSnappr
                  • Jul 2015
                  • 477
                  #698
                  way to bounce back :up: and nice work. Im really digging that front suspension setup. What spring rates are you going with on the gc's?
                  1990 325iX - sterlingsilber metallic
                  1991 325i - lazurblau metallic
                  Originally posted by delamaize
                  E30 = Lego for men.
                  • craiggroves91
                    • Oct 2009
                    • 3024
                    #699
                    Thanks! Yeah I'm super excited to finally habe proper suspension.
                    I have 700# in the rear and 550# up front. I'm not going to run a rear bar and see how it feels.
                    1989 BMW 325i SOLD
                    • craiggroves91
                      • Oct 2009
                      • 3024
                      #700
                      Forgot to post this earlier. Front subframe is back in with new redesigned Condor mounts. They are much nicer
                      Drilled the holes for the brake booster relocation and notched the firewall for the steering column.
                      Removed RTABs. This is definitely better than burning them out
                      Installed delrin brake pedal bushings and bronze clutch pedal bushings
                      Installed new front wheel hubs with new dust covers and new nuts
                      Also got wheel studs on
                      Got the proper strut nuts from vorshlag
                      Rebuilt the half shafts
                      Got new parking brake cables installed
                      Installed a differential stud kit from garagistic
                      1989 BMW 325i SOLD
                      • MR E30 325is
                        • Dec 2008
                        • 3300
                        #701
                        Excellent work swapping to a new chassis, though it sucks to hear about your old one.
                        I rocked a 91 318is with an S52. Was a blast. Hope you get to enjoy yours soon.
                        My previous build (currently E30-less)
                        http://www.r3vlimited.com/board/showthread.php?t=170390
                        A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                        • craiggroves91
                          • Oct 2009
                          • 3024
                          #702
                          Thank you, yeah I'll miss the white one since I invested so much time into it. When it comes down to it, an e30 is an e30 and this new one is overall nicer.
                          I can't wait to get it on the road!
                          1989 BMW 325i SOLD
                          • craiggroves91
                            • Oct 2009
                            • 3024
                            #703
                            Oh and here is an update from the new owner of the original beast.
                            He still hasn't welded in new radiator support but it's coming along
                            1989 BMW 325i SOLD
                            • craiggroves91
                              • Oct 2009
                              • 3024
                              #704
                              Installed bronze pivot pin
                              Did the differential flange seals and orings
                              1989 BMW 325i SOLD
                              • eThirtyAaron
                                • Sep 2015
                                • 144
                                #705
                                Any way you can update the picture host?
                                Edit: For the original pictures early on in this thread.
