Just another Alpine late model....
  • broke30
    • May 2007
    • 1019
    Originally posted by GaryE30
    Boo! We should have kept BOTH rear trailing arms from my old e30. The silver car got the passenger side and this car could have gotten the driver side! :)
    Orflz. Yes, I was thinking that earlier today too. Instead, I just order wheel bearings and picked up wheel bearing tools today....
    Max
    • GaryE30
      • 4791
      Its better that way. New vs 170k or so. Can't wait to see more of it. What did you do with the exhaust on the car? OEM or something else?
      PS - I should be getting a 5-speed soon!!! Local guy is parting out a 98 328.
      Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
      • broke30
        • May 2007
        • 1019
        Yes, old bearings are out, new ones will be in on Monday. Here is a quick teaser of the exhaust.
        I'll post more pictures later today probably, still need to find me a sport interior!
        Max
        • GaryE30
          • 4791
          • broke30
            • May 2007
            • 1019
            Orflz
            Max
            • broke30
              • May 2007
              • 1019
              Just a small picture update. Rear bearings are out, amp is wired up, and I had some extra e36 window switches laying around that I put in.
              Some more pictures of the exhaust
              Also, found out my AFM is toast, need another one of those meow.
              Max
              • broke30
                • May 2007
                • 1019
                Got the new rear wheel bearings in, my puller tool didn't work so I unfortunately had to hammer the bearings/hubs in (used the old bearing faced to the new bearing). However, it still has me a little worried. I guess time will tell. However, when driving it now, it is in fact far quieter but there is a slight rumbling from the rear left that goes away when I turn right. It almost sounds like a tire roar though. Ideas??
                Max
                • GaryE30
                  • 4791
                  Could the CV joint be worn out too? I'm not too familiar with them and/or how they wear and what they sound like, but your possible culprits are limited and the bearing is new.
                  Try rotating tires or borrowing a set of wheels you know are balanced and have good tires. Surely someone in Clemson will let the almighty Max borrow some wheels. :)
                  I replaced the front right bearing on the ZJ and I still get some humming when loaded vs quiet when unloaded. I did a tire rotation and the noise remained. I know all my tires are a bit worn unevenly, but if its showing the same symptoms I feel it could be something else. I'm going to assume mine is due to a worn universal joint right next to the hub.
                  • broke30
                    • May 2007
                    • 1019
                    Thanks for the reply Gar,
                    Yea that was going to be my first step was to rotate tires to see if the sound moves. Otherwise, the BMW guys/e30 guys in Clemson are non-existent or not very cool...
                    I figured worn CV joints would click though, I could be wrong though.
                    As for your ZJ, axles are dirt cheap brand new, I'd just replace them if the sound is that bad.
                    Max
                    • GaryE30
                      • 4791
                      Shit, get David to bring down a set of wheels from the red e30. He's not driving it anyway right?
                      • broke30
                        • May 2007
                        • 1019
                        No, he's looking for a gayrage to set the car into to do his 24v. I flip flopped the rear tires to see if the noise ensues.....
                        Max
                        • broke30
                          • May 2007
                          • 1019
                          Got my IS lip on, and switched the two rear tires. Drove it to work this morning and it continues to make the "tire roar-ish" noise. However, it goes away under moderate to hard braking.... Thoughts?
                          Max
                          • cormier
                            • 380
                            Sooo clean looking awesome man love the alpine. Will be my next e30 color for sure
                            • broke30
                              • May 2007
                              • 1019
                              Vinyl black sport seats acquired. The mechanisms need some work though, but overall, much improved on the inside! Will post pictures later
                              Max
                              • GaryE30
                                • 4791
                                Nice!
