WOW, this is going to be great!
Dirty Baja E30
I love how E30 owners go to such different extremes. This build is great! After owning a couple Subarus I have a special place in my heart for RallyX vehicles.-Erik
Originally posted by 87e30I just want to dance with some beeziesComment
So do you have any more info on the suspension setup? I have been thinking of doing something like this for awhile now.Comment
Time for a bit of an update:
Basically started my own company, filed a patent, lots of stuff... so car always came second
. But now I got some free time again so I'm gettin' as much done as I can!
Lately we've made good progress on the suspension. Take a look!
If you are wondering how the hell we bolt the trailing arms on with that square tubing in there...
Simple really. Just use some 12mm chromoly rod to go through both sides instead of bolts! :grin: They are a really tight fit, so we had to drill holes on the end of the rods so we could fit pins in them, and yank them out. We taper the ends like a pencil so they auto-locate the holes inside the subframe.
I had a bunch of leftover 3/16" plates sitting around so that's what we used for all the subframe reinforcements. Much thicker than the subframes metal! But you can see there is a lot of random tabs sticking out the front of the subframe, we still need to chop those off to make it a bit cleaner.
The trailing arms were all reinforced with DOM .120 tubing. Complete overkill! :D
I'd be willing to bet this is probably the strongest stock geometry e30 suspension on the planet. Why keep the stock geometry? I have no idea
Well, other than the fact I have to use coilovers now.
Oh, and here's a lovely shot of me looking wall-eyed in a giant hole in the trunk:
Late model granitesilber 325i convertible FS:
http://www.r3vlimited.com/board/showthread.php?t=293701Comment
With what we have just seen I can imagine. I knew it was going to have to be unique seeing as how both of your stock mounting points are certainly not optimal (spring seat being inaccessible, and damper mount being far too weak)
Can't wait to see what you've come up withLate model granitesilber 325i convertible FS:
Did a test fit of everything today, and put the bearings and hubs in (thanks to the Harbor Freight tool!). Used a lot of antiseize. So far it is all fitting properly. Sorry this is the only pic I have for now.
Looks like I'll be able to get roughly 8-10 inches of travel with the right coilover. The differential will be lowered by about an inch using spacers between the diff and subframe, which will give me a little more downward travel from the cv's. Gotta reinforce the subframes diff mount area now :loco:
The shocks I was going to use are going to be a really tight fit between tire and body. The springs are roughly 3.75" in diameter. Gonna get wheel spacers now just to be sure.
More to come soon...sigpicComment
