epiphy what do you plan to do with it when its done, are you building it for high speed desert racing/prerunning, or more slow paced trails?
Dirty Baja E30
¯\_(ツ)_/¯
I'm attempting to fit coilovers so I can do both. But realistically, mostly slow trails.
If I was going to do ONLY slow paced trails I would probably go with an air shock from fox or king. They don't need a coil spring since the air inside acts as the spring, so would have no trouble fitting back there. Though there are other disadvantages... like you DEFINITELY would want to keep the swaybar since they tend to be loose at the top (progressive rate). And you would need some kind of bump stop in case a seal leaks on the shock, since if you lose air, it's like losing a spring.
I'm going over to the local off road shop on Wednesday and see what I can figure out.sigpicComment
Are you referring to that hole in the frame?Comment
It does, but the reluctor ring for vehicle speed has to be swapped over to the e36 unit, or needs to be trimmed down - otherwise the "tabs" sticking out will hit the speed sensor and/or cover. I have done 2 conversions, personally, once I used the e36 ring, the other time I cut the ring down ~1/4". Both ways worked perfectly fine.Comment
Great thanks for the info.It does, but the reluctor ring for vehicle speed has to be swapped over to the e36 unit, or needs to be trimmed down - otherwise the "tabs" sticking out will hit the speed sensor and/or cover. I have done 2 conversions, personally, once I used the e36 ring, the other time I cut the ring down ~1/4". Both ways worked perfectly fine.
I've never worked on a diff before. How difficult is it to get the reluctor ring out? We were planning on going to a yard tomorrow and picking up the cover, sensor and ring from an e36.sigpicComment
its there for no good reason. bent it out of the way to gain more clearance with the suspension-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
First take the cover off. The output flanges "pop" out. Pry them a little, even yanking on the axle will sometimes get them. Undo the 13mm bolts and pull the carriers out next. Then you will have a free floating center section that can be removed through the rear. The reluctor is held on by friction/spring effect, the metal is bent in towards itself to lock it in. You will know what I mean when you see it. Carefully pry the ring off, it just pushes on when installing. It's all pretty simple.Comment
