1984 325e S52 swap...
  • vwtech
    • 109
    BMW parts/servicing list:
    project 1984 BMW 325e.
    3.3 L S50/S52 engine swap
    Getrag 250 trans
    2.79 LSD rear/fresh fluid/additive
    It's still a work in progress but the end result was turn key started right up. Compared to the way Vw or Audi does things, BMW makes it much easier!
    Block was magnafluxed and cleaned down to bare. needed pistons because 4 of them measured small. Also resurfaced top of block and bored out pitting in cylinder walls. So as of now it's a 3.3 liter S52. The cylinder head (S50) used was one that had professional flow bench tuning/port/polish job and had been cleaned and minimally resurfaced. The valves and seals are new also.
    2 machine shop bills
    Main and rod bearings
    Wiesco .25mm over pistons
    Arp head stud kit
    Arp main stud kit
    Arp con rod bolts
    Cometic MLS head gasket .080
    Valve Lifters
    No A/C
    No power steering
    Power Steering block off adapter
    Fresh cylinder head
    Port /polish on head
    New valves/deals
    (Minimal resurfacing of head .004")
    Oil Pan
    Oil pump rebuild
    All engine seals and gaskets
    Vanos spring washer/hardware
    Timing chains
    Timing chain guides/bolts/all hardware
    Timing chain tensioner
    All timing cover seals
    Green engine mounts
    AKG poly trans mounts
    Z4 shifter/linkage
    Gearbox fluid
    UUC lightweight flywheel
    M3 clutch oes
    M3 pressure plate oes
    3.5" air mass meter
    24 lbs. injectors Bosch evo 4
    Turner Motorsport underdrive pulleys
    Long tube race headers
    Custom V-banded exhaust/mangaflow muffler/custom tip
    VAC custom cams
    255lph fuel pump
    Custom fuel hoses/filter setup
    Cleaned fuel tank
    High flow air filter setup
    Custom TRM tuning EEPROM
    Spal fan wired through high speed relay
    3 pin fan switch
    Full obd 1 wire harness
    Old body e30 adapter harness
    Crank sensor
    Cam sensor
    Knock sensors (x2)
    Obd2 crank sensor block plug
    ECT sensor
    Gauge sender
    Radiator
    All coolant hoses/ fab up spider hose to expansion tank
    1 coil
    Emblems
    Alternator
    Custom size serpentine setup belt
    Coil over suspension JOM
    Control arms
    Poly control arm bushings
    BF Goodrich g-force sports 215/50/15 tires
    TR Motorsport 15x8 wheels
    Front strut bearings
    Rear shock mounts
    Need Volkswagen/Audi/TDI/BMW service or performance??? Check us out online at www.pdautowerks.com
    Call or email us today to setup an appointment!
    jeremyhoover@pdautowerks.com
    PD Autowerks track car- 1984 BMW 325e...http://www.r3vlimited.com/board/showthread.php?t=239899
  • dirty30
    • 3010
    You forgot pictures dummy
    And there you have it, S52 in an 84 in eight easy steps!
    • zig553
      • Sep 2011
      • 189
      The perfect sleeper...
      • freeride53
        • 11972
        Holy fudge sleeper.
        1983 Peugeot 505 STI
        1992 Volvo 240 Wagon
        • hpde30
          • Aug 2011
          • 76
          very nice!
          • vwtech
            • 109
            Yeah me and trying to post up pictures didn't really work.
            Well from how it looked in the picture of it in the shop, I have drilled and smushed in the front and rear bumpers, fixed the oil press gauge wiring, installed my momo hub and momo corse wheel, and going to install a 318i firewall harness cover.
            • vwtech
              • 109
              Thank you to Ryan for posting up the pics of the build, also it would not have been possible to build the car without Ryan. Thanks for help and technical support!
              Will try to get some recent pictures up, installed a air/fuel ratio gauge, replaced the fuel sending unit, and got the firewall cover mounted.
              Thanks to all who posted!!!
              • vwtech
                • 109
                • vwtech
                  • 109
                  So that's how she sits now, can't wait until I get a 3.25 LSD diff, the current setup has so much gear to pull through. I think it will feel much faster with less gearing to go through.
                  Plans are to weld up or get some race seats and probably some type of cage eventually. Also install poly bushings in the rear.
                  • samiam3356
                    • Jul 2009
                    • 1901
                    Very nice, quick work! Looking forward to the dyno numbers and graph. :)
                    Originally posted by Roysneon
                    $5 shipped?
                    Originally posted by MarkD
                    You are a strange dude, I'n not answering any more posts from you.
                    • vwtech
                      • 109
                      Yeah I may go this Saturday and do 3 pulls. Will be looking forward to seeing the results. When I get the dyno sheet, I can send them into trm tuning and they will review the graphs, make corrections and send me an Updated EEPROM. It should be in at least the 260 whp range I hope. So we will see...
                      • vwtech
                        • 109
                        Got to put these on!
                        Lowered the rear today
                        Here's an interior shot
                        • vwtech
                          • 109
                          So this is what the car used to look like:
                          • davem
                            • Jun 2010
                            • 705
                            very cool project
                            • freeride53
                              • 11972
                              you should put a 318 badge on the trunk :D
