2.7i stroker
  • da-real
    • Mar 2012
    • 23
    Originally posted by trackjunkie21
    What suspension is that in the first pic?
    H&R cup kit allround, 60-40% low. they go for about 1100euro's a set here in europe
    • VinniE30
      • 2113
      Originally posted by da-real
      the beauty: s85b50 type3 (last model) with 72.000 km, and the original sport gearbox.
      That's an S62
      The S85 is the V10 from the M5 or M6
      Zinno '89 <24v swap in progress>
      • entrepreneuR
        • 206
        GOod work! It's nice to see some strokers being built instead of a complete swap.
        • Dirtboy
          • 458
          Very nice!
          Nürburgring info
          • da-real
            • Mar 2012
            • 23
            thnx guys!
            @:vinnie30, youre right..my mistake. changed it ;)
            • da-real
              • Mar 2012
              • 23
              • ohthejosh
                • 4963
                nice matching dipstick lol awesome build man.
                SO MUCH MORE TO DO!!
                IG: ohthejosh
                LEGIT CHECK ME BRUH
                BUYER FEEDBACK THREAD
                • da-real
                  • Mar 2012
                  • 23
                  haha, yeahh a red one was standing out to mutch in all that blue, so we go with the flow :)
                  • iXguido
                    • Nov 2009
                    • 729
                    nice work! when does it hit the dyno?
                    • ak-
                      • 12422
                      More info on the kart.
                      1991 325iS turbo
                      • da-real
                        • Mar 2012
                        • 23
                        not for long, got to make about alot of miles first to "run in" the engine..
                        and I want give it a e85 fuel setup to give it a little bit more horses
                        • da-real
                          • Mar 2012
                          • 23
                          ask what you want to know..
                          900cc honda fireblade engine, frame is streched to fit the engine, that is done by a prof. engeneering company. got some custom made stonger cnc made bearing houses for the rear axle.
                          disk brakes front and back. and "old skool" 30mm solid rear-axle. (new ones are all 50mm and hollow, and already break alot on normal karts)
                          it's alot off custom work so it doesn't go so fast with 3 bimmer projects to.
                          the shift system is already done. now to do the wiresystem and the gas/clutch cables. waterhoses I'm gonna make from QSP universal pieces.
                          I mouted the cooler on the back in lack off space, so it needs an electric fan.
                          frame is still bending a little bit in the middle because off the weight so needs some good welding in the right place
                          but is sitting in a corner now waiting for some work to get done, cause off other stuff
                          • da-real
                            • Mar 2012
                            • 23
                            nice and clean head, just how we like it..
                            • da-real
                              • Mar 2012
                              • 23
                              • structured
                                • 954
                                What rods and pistons are you using? I think that you and I are running the same setup. I could never get the 288 cam to fit, though. Even with the adjustable cam gear, the valves were contacting the pistons.
                                I used the following:
                                - eta 81mm crank
                                - eta 130mm rods
                                - New super eta pistons
                                - 325i head
                                - New OEM valves, rockers, etc.
                                - Metric Mechanic Beehive valve springs
                                - 272/272 cam (because the schrick 288 wouldn't fit)
