My '75 2002 Sleeper
  • slowe34
    • Sep 2011
    • 206
    #406
    This thread is the reason why I come back to check on the project forums.
    Glad your back and doing better. Your work is inspiring.
    • tinkwithanr
      • Jun 2010
      • 377
      #407
      Thanks for the support guys.
      Sadly my ebay addiction continues. This is only part of the newer direction:
      More to come.
      Tinker Engineering - 2014
      Mica - 2000 BMW 323i - The one that started it all
      Fiona - 1975 BMW 2002 - The Definition of Project Creep
      Heidi - 1988 BMW M5 - The piece of BMW history
      Silvia - 2013 Subaru WRX - Stock, for now
      • deutschman
        • May 2008
        • 5958
        #408
        Oooooh dry sump!
        • knuklehead92
          • Aug 2011
          • 732
          #409
          ahhh snap dry sump!!!
          this means business!
          Trust me it stock :yawn:
          • JCarp90
            • Feb 2011
            • 1759
            #410
            • tinkwithanr
              • Jun 2010
              • 377
              #411
              Originally posted by JCarp90
              lmao
              And then he said,
              "Let there be brakes!"
              And it was good.
              Front:
              6-Piston Forged Calipers
              300mm (11.75") x 32mm (1.25") vented 2-piece rotors
              Rear:
              4-Piston Forged Calipers
              Retains Stock Hand Brake
              The front and rear will share the same rotor disc, so maintenance/replacement will be easy. The brake bias is kept at the proper ratio due to the difference in the piston area for the 6-pot front and 4-pot rear calipers. It can then be fine tuned with the balance bar pedal setup and by changing out the master cylinders if need be.
              • matthugie
                • Mar 2004
                • 1810
                #412
                Damn, now those are some brakes!
                88 325is - S52 powered
                Originally posted by King Arthur
                We'll not risk another frontal assault, that rabbit's dynamite!
                • bsturman92
                  • Sep 2012
                  • 282
                  #413
                  i wish i was related to you.. this shit is godly.. truely amazed... i sat here at work the last 2 hrs going over this entire thread... i give you a HUGE thumbs up man! very impressive shit
                  • Denny
                    • Jan 2010
                    • 822
                    #414
                    Originally posted by tinkwithanr
                    lmao
                    And then he said,
                    And it was good.
                    OMG!! BANG!!:twisted: what an evil build...
                    Denny
                    ___________
                    1990 BMW red 325IC M30B35 all stock Girlfriends ride
                    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
                    Blogs:
                    http://bmw325e30.blogspot.com/ (restoration)
                    http://bmw325e30turbo.blogspot.com (Twincharge M20)
                    http://bmw325e30m62b44.blogspot.ca/
                    • deutschman
                      • May 2008
                      • 5958
                      #415
                      So do bigger brakes mean there will be more POWER!?
                      • doucy2
                        • Sep 2006
                        • 1311
                        #416
                        Well 28 pages later this has been one awesome build thread. I am def tuned in for the long haul. Where in Ohio are you located? If you are close I would certainly come out and lend a hand if you needed it for anything.
                        • tinkwithanr
                          • Jun 2010
                          • 377
                          #417
                          :up:
                          Eventually... The base power plant hasn't changed. Just other parts of it.
                          Thanks, I'll keep that in mind. The shop in in Springfield, where are you located?
                          • justlikeyours
                            • Mar 2013
                            • 21
                            #418
                            hope one shows up on cl near me for cheap =\
                            • doucy2
                              • Sep 2006
                              • 1311
                              #419
                              Located in Chillicothe, I went to school in Springfield (Wittenberg), so got lots of friends up in the area.
                              • benyen soljax
                                • Mar 2012
                                • 290
                                #420
                                And tink delivers.
                                Project 325is
                                Transaction Feedback
