FORGED FULLY 🐬 grey S50,shaved, KW, brembos, garret g30/770 fr&rear 5 lug,
  • e30m20TurbO7
    • 1203
    I'm only in it about 800.
    So far
    Originally posted by ttrousdell
    Unbolt the connecting rod caps then push the rod and piston out of the block. Keep everything in order. Nice find for 300.
    • F34R
      sLaughter
      • 12376
      Originally posted by e30m20TurbO7
      Thanks for the tip If I post some pics of my cylinders. Can you tell me if to need to be honed
      So far
      Post up a few pics of the top edge of the cylinders and a downward shot into them with good lighting. But since you have the block out a nice cross hatching would be wise with new piston rings.
      When you remove them mark the pistons and rods to the correct cylinder they came from. 1-6 front to back is how I do it when I tear down my blocks. I use a grease marker and just # the block on the outside of the cylinder walls, and on the tops of the pistons. I also suggest if you're removing them to have the block milled.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • e30m20TurbO7
        • 1203
        thanks for the tip 2 cylinders im worried about, the cylinder closes to the firewall still has the original cross hatching on it visible
        il snap some pics for all you to see when i have the block dissassembled
        this is my first water cooled engine rebuild soo i could use all the help and advise i can get
        • e30m20TurbO7
          • 1203
          also do i need to buy new rod bolts if i rebuilding the bottom end?
          • FLG
            • Sep 2011
            • 3165
            You'll be fine reusing the bolts.
            Sent from my Galaxy Nexus using Tapatalk 2
            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
            • e30m20TurbO7
              • 1203
              Help Find me pistons
              • e30m20TurbO7
                • 1203
                Primer
                • e30m20TurbO7
                  • 1203
                  no support :puppy:
                  so
                  • e30m20TurbO7
                    • 1203
                    my block just got sent in to the machine shop heres the engine bay so far
                    Short shifter came
                    I wonder what this is !
                    My trunk
                    Wrinkle high temp paint crappy pics
                    • e30m20TurbO7
                      • 1203
                      all my rebuilding materials are in the mail
                      cant wait for my parts
                      • sayed ali
                        • 762
                        Good luck
                        Nice paint job :)
                        M20B28 Turbo
                        My Build Thread
                        http://www.r3vlimited.com/board/showthread.php?t=255839
                        • kingston
                          • Jun 2010
                          • 2669
                          Paint and seats look great! What paint and equipment are you using for the paint?
                          Originally posted by LJ851
                          kingston is the play by play announcer for this thread.
                          β€˜Tis by the grace of God that my cars run!
                          Originally posted by unloadedak
                          #teamross
                          Siobhan's Build Thread - UPDATED!
                          • e30m20TurbO7
                            • 1203
                            i used sem paint code match paint its a paint code match base coat in a can. I shot it would 2 cans they cost 24.64 a peice and they mix it up when you buy it. I'm going to wet sand with 1500 grit then 2000 grit re shoot a wet coat then shoot my clear
                            all sem products
                            • ak-
                              • 12422
                              I was under the impression that you're not suppose to reuse connecting rod bolts.
                              1991 325iS turbo
                              • e30m20TurbO7
                                • 1203
                                i know thats what i thought. i just dont feel like dishing out the cash for 72.00 bucks in bolts
                                when mine literally look perfect. But if someone here thinks that my engine will fail let me know.
