FORGED FULLY 🐬 grey S50,shaved, KW, brembos, garret g30/770 fr&rear 5 lug,
  • Vtec?lol
    • Dec 2009
    • 3278
    #166
    Originally posted by e30m20TurbO7
    First of all, I used brand new bearings on the rods and mains , there's nothing wrong with re-using piston rings off a motor that ran and if its going on to the same cylinder that it began in , I have perfect compression , no rod knocks nothing was half ass on my build .
    The only thing I should have done was buy a new oil pump.
    New bearings
    New guides
    New stem seals
    3 angle valve job
    I have hundreds in just machine shop fees .
    All new seals throughout the whole motor without a single leak , I didn't do anything incorrect on my build.
    My oil squirter tube was clogged from debris in the oil so I burned a cam lobe and rocker , wooptee doo
    I spent more money than you could possibly think is possible for this motor.
    Reusing my rings may have been a risk but how come I have perfect compression , hmmmmmm well I have nothing to prove to you , but I take offense to people who have negitive opinions to say how about how I built my engine when I doubt you even attempted something as challenging and time consuming , as I have .
    My rims are multi colored because its below 35 outside . I doubt goo off is going to take 3 layers of paint off my wheels .
    Whoa there.
    • efficient
      • Feb 2012
      • 3312
      #167
      • 2mAn
        Señior Mod
        • 20114
        #168
        I've got all good compression in all the cylinders
        #1 92
        #2 90
        #3 89
        #4 91
        #5 93 cylinder with rocker noise
        #6 90
        Simon
        Current Cars:
        -1966 Lotus Elan
        -1986 German Car
        -2006 Volkswagen Jetta TDI
        Make R3V Great Again -2020
        • e30m20TurbO7
          • 1203
          #169
          New shift knob
          Smoked signals
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            #170
            Engine has half of correct compression.
            Buys new shiftknob.
            Memeworthy if I've ever seen it.
            • e30m20TurbO7
              • 1203
              #171
              Here's my spectacular update , thanks to hoodlems who don't like my car Appernttly
              Only people with nothing better to do , comment on what I do with my money , mind your own buisness , my project thread isn't a place to post your opinion .
              Buys new shiftknob.
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                #172
                I've got tons better to do, I just choose to post my opinion in your project thread, if it wasn't the truth and you knew it, you wouldn't have been offended.
                • e30m20TurbO7
                  • 1203
                  #173
                  Did anyone ask for you opinion , Noo . Frankly it didn't offend me , they were gifts so I didn't even think twice about your "memeworthy" BS . I don't nessacarely drop it when people post rude things , with out expressing my opinion . You obviously don't have anything better to do because you replied to my post with in like 2 minutes . But whatever
                  Buys new shiftknob.
                  • Cronopoulos
                    • Jul 2011
                    • 2187
                    #174
                    Oo lawd
                    Project log -- DIRTY 30
                    2.7i * Megasquirt tuned * E85 powered
                    • Justin B
                      Sikky Nar Nar
                      • Mar 2005
                      • 4273
                      #175
                      Sure you're not missing a 1 off each one of those numbers? Good lord.
                      • Cronopoulos
                        • Jul 2011
                        • 2187
                        #176
                        is timing off a tooth?
                        • e30m20TurbO7
                          • 1203
                          #177
                          My compression is fine I later found out it happend to be the gauge .
                          I put oil in my cylinder and ran a compression test . All my numbers when up to 120-125 psi
                          • e30m20TurbO7
                            • 1203
                            #178
                            It's been pretty cold latley , getting down to the negitive's
                            But today I got adventourous , and decided to put on some stuff I had lieing around on
                            I spent a good two hours making it 100% straight with some wood , hammers and Dolly's
                            I need to start paint and body I spring
                            • efficient
                              • Feb 2012
                              • 3312
                              #179
                              so you ever figure out what was wrong with your motor?
                              • FLG
                                • Sep 2011
                                • 3165
                                #180
                                Oil in the cylinders bumping up compression points too bad rings
                                Sent from my Galaxy Nexus using Tapatalk 2
                                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
