TheTacoMan's build, Turbo'd, mflare'd.
  • Denny
    • Jan 2010
    • 822
    #226
    Originally posted by TheTacoMan
    Wheels are mounted, 255s in the rear
    DA waffleswaffleswaffleswaffles!!!!! You bring me back my wheels now!!
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
    • TheTacoMan
      • Nov 2011
      • 2308
      #227
      • TheTacoMan
        • Nov 2011
        • 2308
        #228
        Dem flairs
        • thatphysicsguy
          • Mar 2013
          • 843
          #229
          Lookin' good!
          '91 325i
          • GAbOS
            • Mar 2012
            • 523
            #230
            Looking real good!
            • TheTacoMan
              • Nov 2011
              • 2308
              #231
              Five speed swap is nearly done, and I also found out why one side was slightly lower. Im missing a front sway bar mount, its gone. So I need to figure that out.
              • Dj Buttchug
                • Jun 2010
                • 7686
                #232
                its just so damn beautiful
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • TheTacoMan
                  • Nov 2011
                  • 2308
                  #233
                  5 speed is in and driving
                  • Denny
                    • Jan 2010
                    • 822
                    #234
                    DAMN SON car looks amazing!
                    Denny
                    ___________
                    Blogs:
                    • thatphysicsguy
                      • Mar 2013
                      • 843
                      #235
                      So beautiful!
                      But with the herrafrush is the handling kinda sketchy? Or did you already have zero suspension travel to speak of when you were running the TRMs?
                      '91 325i
                      • sayed ali
                        • 762
                        #236
                        Nice car :)
                        Needs M tech 1 wing (IMO)
                        M20B28 Turbo
                        My Build Thread
                        http://www.r3vlimited.com/board/showthread.php?t=255839
                        • TheTacoMan
                          • Nov 2011
                          • 2308
                          #237
                          Originally posted by thatphysicsguy
                          So beautiful!
                          I had good travel with Trms, That stupid broken sway bar mount is making my car lower. Rubbing is minimal even being stupid low on huge tires.
                          Im getting a new sway bar, getting in reinforced and some street camber plates to raise it 1/8" and to give me a bit better clearance.
                          I rubbed with 225/50/15s because of that broken sway bar issue that I just found.
                          Tight clearance as you can see
                          • thatphysicsguy
                            • Mar 2013
                            • 843
                            #238
                            Oh got it, good luck with that. Are you gonna try to upgrade the sway bars? or just fix the mounts and put stock sways back in?
                            '91 325i
                            • TheTacoMan
                              • Nov 2011
                              • 2308
                              #239
                              Im going to upgrade sway bars, I need the extra stiff.
                              • chondamx
                                • 247
                                #240
                                Cars coming along nicely! Where did you end up buying your wheels from?
                                '91 318is M52 Turbo (in pieces)
