Went out today to work on the front suspension. Ugly had a little surprise for me:
At first I thought that my rear main leak had gotten WAY worse, but upon further investigation, it's brake fluid. Ah, that's not a shock. See, the car is very clean underneath, but there is one rusty spot right along the left-side frame rail, where 3 hardlines go:
Oh, yeah. That sucker split right open. And the fuel lines next to it don't look much better. I was always planning on replacing all of them before the car saw the road, so no big deal.
Anyhow, on to the front suspension. I expected to have trouble with the rotor retaining screw, and I wasn't disappointed. Tried moving it with an allen wrench and it laughed at me. Tried it with a hex socket and stripped it out good:
So, I commenced trying to drill it out. I don't know what that screw is made of, but I didn't have the easiest time:
After drilling it out as much as I good, I went to a combination of a BFH and a little heat:
Success! Back of the rotor is a little beat up, but I'm replacing it anyhow:
Ball joint coming apart:
Another surprise, on the other side, the screw came right out:
I'm a little curious as to what this wire is for. My car doesn't have ABS. This is on the driver's side, there wasn't one on the passenger's:
So, the struts are off. The steering rack is from my E36 M3, I'm going to get it rebuilt and put it in this car.
Next steps will be to remove the rack, the front control arms, and the sway bar. I'm replacing nearly everything. Essentially the only part of the front suspension I'm going to reuse is the spindles. I have new (to me) Bav Auto springs on the way, I'll be getting Bilstein Sports, new control arms, new hubs, and I need to pick out a set of sway bars. The E36 rack will get new tie rods, as well.
