★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
  • lambo
    Captain Scene Points
    • 10953
    #1711
    Originally posted by Dj Buttchug
    give me that selector rod
    bruh shoulda copped one during Black Friday...they were only $60
    • Dj Buttchug
      • Jun 2010
      • 7677
      #1712
      will it work for e36 m3 with tunnel mounted shifter... lol I need a custom length so I may have to make my own
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • ak-
        • 12422
        #1713
        I know those are solid, but yeah I was skeptical of the poly mounts I bought from Garagistic because I don't want any vibes from the drivetrain either, but was pleasantly surprised that the only rumble I slightly feel is the first throttle blip from idle to moving.
        Everything is gravy after that. Trans is stock rubber.
        The only poly item I regret though is trailing arm bushings - mine squeak sometimes.
        I want to see more bewst items though.
        1991 325iS turbo
        • wworm
          • Dec 2016
          • 1719
          #1714
          Kronus mentioned it in his thread with his black coupe iirc. Def going to have to snag a pair for the California cuckhold that is BAR but I plan on swapping in some long tubes down the road for those brapps
          1984 Delphin 318i 2 door
          • lambo
            • 10953
            #1715
            Well this one is a 10 degree twisted one so I can use the G260. Idk if Garagistic makes one for E36. However, I have their old style M20 DSSR on my car right now and I have a PMC shifter and it's fine.
            Yeah I have solid motor mounts and stock rubber trans mounts right now. Probably going to keep it the same for the swap. I only notice the solid motor mounts on startup. I still have fresh OEM rubber in the rear so that's good for now. Probably going to switch to Condor stuff when I decide to reinforce the subframe though.
            • lambo
              • 10953
              #1716
              Why fix your good wheels when you can just buy shitty replica wheels?
              don't worry they're just dorifto fuck boy spares
              • Wschnitz
                • 8089
                #1717
                ur dumb btw
                willschnitz
                • ak-
                  • 12422
                  #1718
                  You mean dr1ft wh33ls.
                  1991 325iS turbo
                  • lambo
                    • 10953
                    #1719
                    Originally posted by Wschnitz
                    ur dumb btw
                    I agree
                    ;D
                    They were only $200 for the set so I couldn’t say no to some cheap dorifto wheels
                    • lambo
                      • 10953
                      #1720
                      Don’t hate me... I already hate myself enough...
                      I was planning on putting all 4 on but because they’re Honda wheels, the fronts won’t clear the caliper even with a 15mm spacer lol. Good thing I really bought them just for the rears...
                      • wworm
                        • Dec 2016
                        • 1719
                        #1721
                        lol dreeeft!
                        whats the offset on those puppies?
                        • lambo
                          • 10953
                          #1722
                          Originally posted by wworm
                          lol dreeeft!
                          They’re 16x8 et20. That’s why I was surprised they wouldn’t clear the front with 10-15mm spacers... oh well...
                          • Wschnitz
                            • 8089
                            #1723
                            >thread title says more doggo
                            >thread lacking in doggo
                            willschnitz
                            • bangn
                              • Sep 2011
                              • 760
                              #1724
                              im surprised at this.. a guy at work has some xxrs on his e30 without spacers and they fit fine, those are 16x8 +25's :S
                              are they hitting the chunky hub or something?
                              Boris - 89 E30 325i
                              84- E30 323i
                              • lambo
                                • 10953
                                #1725
                                Yeah the hub is super chunky. 16x8 et20 should be perfect E30 fitment, these wheels are just shit.
