Thanks for the great intro.
★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
Decided to start dismantling the newish subframe
Quickly realized a couple things:
- I have no idea where my 19mm wrench is
- The hub bolt is impossible to get by yourself with hand tools when the axle is not connected to anything
So I gave up for today and did this instead
20140316-DSC_0049 by P.C.Kaptures, on Flickr
Originally posted by SpasticDwarf;n6449866Honestly I built it just to have a place to sit and listen to Hotline Bling on repeat.
are you refreshing that subframe to replace yours?1997 Audi A4 1.8t 5-Speed (bamboo metallic): ST Coilovers, Sport Edition 17x7.5 Et35, 215/45/17 Kumho AST, Panzer, Depo Ecodes, 55w 5k bulbs, Magnaflow 14815, Res delete, JHM Vent Boost gauge
2001.5 Audi s4 2.7tt 6-Speed (Imola Yellow)
<<Flickr>>
Finally fixed my stupid headlights! Got my new headlight bulbs in from XINGHUA City. This will probably be the last time I order from DDM tuning...
The culprit...
wham blam thank you ma'am
Originally posted by 325i View Postare you refreshing that subframe to replace yours?
I'm gonna do everything out of the car and then swap em out some day. Revshift 80A bushings all around and I decided against toe correction because I'm going on air eventually.
Originally posted by Jb325is View PostCar looks awesome, love it with the Futura's.
On the axle nut, you could maybe put two lug bolts in the hub and wedge a pry-bar in there, then use a breaker bar to break the nut free. Or pry bar to hold lug nuts and good electric impact would definitely get it off.
Originally posted by Zreberlcoe View PostI like DDM. They're in my fogs and headlights.Last edited by lambo; 03-17-2014, 03:34 PM.
Originally posted by 325ix View PostHow do you like them in the fogs? I can't even imagine needing them. I have them in my depo smilies (both hi and lows) and turning on the highs doesn't even make a huge difference.
I like them a lot! Besides they're kind of a pain to install, they look damn good! I left my high beams alone, they're definitely needed.1991 325i Calypso Coupe
Like Grandfather, Like Father, Like Son
BMW
Originally posted by lambo View PostEhh, they're not bad but there are much better options out there. I plan on upgrading to some morimoto stuff when I pick up some depo smileys.
Truth.
DDM bulb temps are suspect and the ballasts are hit or miss, in my experience. Morimoto is high-quality stuff from bulb to ballast. I use their kits in both my cars. Wouldn't run anything else other than OEM stuff like DENSO or Matsushita.
