★ ★ Project Glacier | Make the E30 a Daily Again ★ ★
  • AbsorbantNut
    Non faccio funzionare questa merda
    • Jun 2010
    • 2491
    #1231
    Originally posted by AbsorbantNut
    I have a friend running 225/50s on style 5s with 18mm adaptors. He's on h&r race w/ bilstein sports. You'll need a fender roll for those, but 205s shouldn't be an issue.
    I haven't been in the car since he moved & got the wheels, but he hasn't told my about any issues. If it rubs I can't imagine it being terrible, he'll normally tell me if somethings up with the car.
    he has camber plates up front if that helps.
    -edit- just saw your edit. Not sure, when he texted me that he got 225s I assumed all around. I'm going to be quite the jackass if they arent up front
    But in all seriousness, with a fender roller you can pull the heck outta the front fenders. I messed around on my e30 and added something near an inch(~25mm) of width
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
    • mbonanni
      • Sep 2011
      • 6236
      #1232
      You already mentioned it earlier anyways. Either way, he rubs like hell. No doubt.
      • AbsorbantNut
        • Jun 2010
        • 2491
        #1233
        So is it possible for 225 all around? I am going to say yes. Possible without rubbing? If you have coils w/ a suitable spring rate yes. On lowering springs, no
        • mbonanni
          • Sep 2011
          • 6236
          #1234
          Lets go with that.
          I hardly ever rubbed in the rear with zero roll and that setup. I had to have a rear seat full of people to rub in the rear. The front is more my concern. At et 20 my fenders got trashed even at that height. I was running 500f/700r gc and revalved bilsteins.
          • lambo
            Captain Scene Points
            • 10953
            #1235
            My old setup compared to E38 Style 5's with 18mm/20mm adapters and 205/50's
            Front
            Rear
            • AbsorbantNut
              • Jun 2010
              • 2491
              #1236
              what app is that?
              • lambo
                • 10953
                #1237
                what app is that?
                bruh
                bruhh
                I thought you was a stance offset flush master level 72
                Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.
                • mbonanni
                  • Sep 2011
                  • 6236
                  #1238
                  The height in the front might be problematic, but looks doable if I pull a little but. I am going to try it out once I get my new suspension on and report back.
                  • lambo
                    • 10953
                    #1239
                    If you're not slammed and have camber plates you should be fine
                    • lambo
                      • 10953
                      #1240
                      I would literally trade you my wheels with 205/45's for yours with 205/50's lol
                      • AbsorbantNut
                        • Jun 2010
                        • 2491
                        #1241
                        Originally posted by lambo
                        bruh
                        bruhh
                        http://www.willtheyfit.com/
                        :rippedoff: I've been messing around with washers & math this whole time and there's a legit website for this type of stuff!!??!?! :hitler:
                        side note- my friend just texted back and says he only rubs on hard bumps/pot holes in the rear, not under accel. But he didn't mention extra people in the back. It'll def rub if you're rolling deep with the squad waffleswaffleswaffles, as mbobannie said
                        • AbsorbantNut
                          • Jun 2010
                          • 2491
                          #1242
                          The pull will solve all. And a splash of camber if you don't want to pull them aggressively. You don't even need to get adjustable ones, you can run fixed plates from IE. What's your new suspension?
                          • mbonanni
                            • Sep 2011
                            • 6236
                            #1243
                            New suspension is the catuned couls. So it will have camber plates and 450f/650r. I will be putting adjustable camber on the rear as well, just not sure when.
                            • lambo
                              • 10953
                              #1244
                              Yeah then I wouldn't worry about fitting 205/50's. Might take a little bit of dialing in but rolled fenders should accommodate it easy.
                              • AbsorbantNut
                                • Jun 2010
                                • 2491
                                #1245
                                Why the jump from ground control to cat? Are the bilsteins just getting tired?
