Well, the weather did not cooperate and the motor swap did not happen. It was calling for a high of 32* (I think that it did get up to 34, to be fair). We postponed the swap.
I had these all ready to go on:
I figured that I would get a little work done. Bad idea. It was 28* out and with the driveshaft disconnected I worked on the car outside. It took almost 90 minutes to get one Condor M3 CAB installed.
I take that back...It really took 75 minutes to get this OFF:
And 15 minutes to press and install the other Condor one.
In other news, I got a set of used OMP seats and some 4-point Schroth harnesses.
The driver's seat has an e36 Corbeau base and sliders. I need to snag an e30 base.
On the passenger side, I think that I can make the previous owner's brackets work with the OEM sliders.
With the lift, 99% of what I do on my own will be more simple.
Lift:
The lift is an Atlas TD6MR. They run about $1600 shipped and I got it for $1000, gently used. The guy flaked on giving me the truck adapters (which I need for my truck) and they run $160. He actually called me the day after I picked up the lift to tell me that he has them but has not called back or answered the phone in 2 weeks.
How does is that lift secured to the floor? Easy to move from a current garage to another? I assume it uses a 115 cord to power a hydraulic pump?
The lift rests on the floor and is "portable" but only in the sense that it isn't bolted down. It weighs about 1000# for the main unit, give or take. It is easy to move forward and back, but even moving it from one side of the garage to the other is a bit of a PITA. I would NOT want to move it to another house without an engine hoist and a low trailer. I built ramps to allow me to park over it at night, so it isn't too portable at all right now.
The hydraulic unit is a 115V 15A circuit.
It goes much higher than that but I had the garage door open and the antenna was hitting the door. I folded the antenna and it went up another 6" but it goes up to about 4' in total height if I have the door closed.
If those stock exhaust studs become a PITA to install I highly recommend studs from an E90 since they have an E-torx head making them very easy to install (provided you have an E6 E-torx socket or wrench.)
Part number: 11127593376
What they look like:
If you have the engine out of the car (which I think you do) double nutting the stock ones should be easy enough but a royal PITA on an engine installed in the engine bay. I'd still be double nutting studs on my E36 if I didn't have these E90 studs a few months ago.
I really wish that I had remembered that before I ordered my OEM ones. I have an e-torx set and those would have been MUCH easier than the 2x nut method.
Sorry to tell you after you had ordered. :(
The E90 studs are cheap (I think I paid ~ 40 cents each for them at most) so you could always order some of them...
I feel really silly...I ordered the 13 OEM ones with 2-day shipping so that I'd have them for my install last weekend and the weather was crappy so I did not do the install. The studs were only about $0.60-0.70 each, but I had to pay to ship them fast. Wasted that $$$.
Oh well.
I might do the install this weekend, btu if I don't I think that I might go ahead and order the e90 studs to make the install easier. Not that double-nutting is difficult, but I can be a lot more confident in the seating with those e-torx buts than with double nuts.
