ditching bmw powerplant, ka24de-t drift car
  • gtdragon980
    • Jun 2008
    • 1808
    IMHO I would rather have a silky smooth boosted six over a boosted 4 banger. Not to mention the engine sounds are godly!
    FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
    Originally posted by scabzzzz
    I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
    1989 325i - Project/weekend driver
    2002 325i - DD
    2005 Suzuki SV650 - Toy
    • lambo
      Captain Scene Points
      • 10953
      Originally posted by F34R
      Owns a smooth running m20...and does not boost it? The m20 will make 300+ all day with a set of ARP and a MLS gasket. Why waste the money swapping another powerplant? You already own the m20, sounds like you only know how to work on rice burner engines. M20>ka whatever
      I'd have to agree... but I see OP's logic given he owns a built S13 already...
      • ACS Cabrio
        • Aug 2012
        • 243
        -dual camshaft
        -hydraulic lifters, no m20 rocker noise or failure
        The parts for more common engines are incredibly cheaper.
        i do not want a stock motor with a turbo on it. its not reliable to be at redline just about all the time
        just about every part is twice as expensive vs the nissan engine
        forged m20 pistons and rods = 1800
        forged ka24de pistons and rods = 800shipped through ken at enjuku
        head studs 120 vs. 230
        mls head gasket 99 vs. 220
        the list goes on.
        • redsubdivisions
          • Feb 2011
          • 1762
          this is full of lols. OP, stick with the stock M20 or swap another M5x/S5x in there and have fun with it and boost that later on when funds permit.
          1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
          2012 Passat TDI - DD Duty
          2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
          • redsubdivisions
            • Feb 2011
            • 1762
            Originally posted by ACS Cabrio
            -dual camshaft
            the list goes on.
            You're insane to think that it will be cheaper to boost a truck motor. I boosted a KA and I will tell you, it is a headache to keep up with and the time it will take to fabricate everything into a different chassis, let alone manufacturer, will burn a bigger hole in your pocket.
            • ACS Cabrio
              • Aug 2012
              • 243
              you posted without reading anything
              I already have the same setup in an s13 and it has been sliding for 3 years
              already have a spair stock longblock and trans i picked up earlier this year for $100
              last time i built a KA bottom end it was $1000 out of pocket. that included pistons, rings, rods, bearings, machine work and balancing
              money is not the issue. just no need to throw any away to maintain manufacturer.
              looking for the most bang for the buck.
              even a used s50 with over 100k miles is 2k without trans or any install parts. and that 240hp
              • camip
                • Nov 2011
                • 1253
                Op do your thing I would have done the same thing as you. You know the ka and already have one. Might not make a better car but it makes a better team.
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  You don't need forged internals to be at redline on boost, even at 350whp. The stock bottom end is deliriously robust.
                  Originally posted by marco88
                  just thought ide share my dyno chart that i got today after another workshop stuffed up my last dyno power run. its a stk b25 with 23yo rings and bearings on 28psi running e85 and a gt35. im happy now that ive cracked 400 :). i cranked the timing up to 20 degres at 2bar from about 6k so it would put out abit more power, which is why power suddenly rises before he backs off
                  from e30tech. don't mind the kick on the graph, say 400whp.
                  All you really need is a good tuner, a good turbo kit, block O-rings, and some good head hardware to bolt everything down.
                  I have experience with KA-Ts; while they make power and are fun to drive, its still a truck motor. To each his own.
                  Camip does makes a good point. I am well versed in boosting m20s, so I am biased.
                  Derek
                  DedericMS
                  • ACS Cabrio
                    • Aug 2012
                    • 243
                    :thup:
                    Derek
                    DedericMS
                    i have seen graphs and power like this, i only have them problem of lifespan. i want this to last a good 3 seasons of track use as my s13 has.
                    • e30trooper
                      • 11576
                      OP thinks m20 parts cost alot
                      To build your current m20 will cost less than just installing a KA in a e30. Have fun getting around the steering linkage and getting a custom drive shaft.
                      Like Derek stated. I would make more sence to boost the m20. Arp studs and a MLHG with just a reseal and maybe a re-ground cam will be alot cheaper than you think.
                      Find a 325e block ( 2.7L with dished pistons) Match up with your 325i head and now you have a low comp boost ready engine.
                      • 5Toes
                        • 9836
                        • CreamBeam
                          • 223
                          its your car do what you please with it, just be sure to post lots of pictures.
                          i personally would go boosted m20, but in the end its your car, so have fun with it.
                          • u3b3rg33k
                            • Jan 2010
                            • 2452
                            N57S swap or GTFO.
                            Ich gehöre nicht zur Baader-Meinhof Gruppe
                            Originally posted by Top Gear
                            Just imagine waking up and remembering you're Mexican.
                            Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
