E30 M3 touring with S62 power
  • iXguido
    • Nov 2009
    • 727
    #46
    Do you plan to cut the panels for the rear doors to open?
    • F34R
      sLaughter
      • 12376
      #47
      So amazing! one day I will have the space for a full body spit strip. For now I live through you!
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • e30edward
        • 777
        #48
        This is going to be awesome!
        • phenryiv1
          • Jul 2009
          • 3246
          #49
          Full of win.
          Patrick Henry
          • DaveG
            • Nov 2011
            • 40
            #50
            Yes I will be keeping the rear doors functional and keeping the door handles.
            • nl328i
              • 556
              #51
              well this makes my s50 swap touring that is under way look pretty damn lame! Haha.
              I'm very excited to see the end result.
              Good luck!
              1976 2002, 1987 325is, s50 1991 touring, 1996 328i vert
              • Turk
                • 223
                #52
                Looking excellent Dave. Let me know when you're ready to send the ecu over for superDuper'ification ;))
                Plug and Play S54 & S62 loom/Ecu Kits - Fit you engine to ANY car!!!
                M50 Sump Baffles
                High Torque Clutch Kits
                Custom Flywheels
                E30 Engine Conversion Kits
                http://www.bmw.ergen.co.uk
                LIKE our Facebook page for regular car porn :)
                http://www.facebook.com/ergenltd
                • iXguido
                  • Nov 2009
                  • 727
                  #53
                  Then you have my attention! Definitely keeping an eye on this!
                  • DaveG
                    • Nov 2011
                    • 40
                    #54
                    Not a great lot of progress to be seen this week. Removed the back panel which was a bigger job than I had thought. A load of spot welds and lots of layers where it meets the wings near the top. Took me about 8 hours in total but its out now.
                    On a side note of something that might be of interest to people.
                    I always new that the sport evo wings had a bigger wheel arch than the standard M3 wing to allow them to fit 18" wheels for competition but never knew how much so measured them up.
                    First standard wing
                    Sport evo wing
                    Top measurement is probably not 100 % accurate but you can see the difference.
                    • iXguido
                      • Nov 2009
                      • 727
                      #55
                      Nice work! Removing that tail panel looked really tedious. You have a brand new replacement? That's interesting about the fenders, are you going with the Sport evo, or the standard wing?
                      • DaveG
                        • Nov 2011
                        • 40
                        #56
                        Yes turned out a bigger job than expected.
                        Putting in a new rear panel
                        Yes im am using the sport evo wings, they are cheaper than standard wings also.
                        • DaveG
                          • Nov 2011
                          • 40
                          #57
                          This weeks update
                          Ground down and cleaned up all the joints in preperation for the new back panel
                          New back panel from bmw, 140 euro which supposed me. You never can tell with bmw.
                          Lots of weld through primer and tack weld in the panel
                          Weld up fully and plug weld to the floor and pockets.
                          Really happy with how it turned out. Really nice to have a lovely straight back panel and valance. Will make a Hugh difference when I put the bumper on and it all lines up
                          I'm waiting on getting 2 new rear quarters so can't do any more bodywork for the moment.
                          I pulled out an old S62 that I had for parts and bolted up a gearbox to it
                          Then made up a pair of engine mounts for it
                          Bolted them onto the block
                          The reason why this is a parts engine. Ouch
                          Yes that is the crank
                          Next up I want to reinforce the front subframe and modify the steering rack mountings for more clearance.
                          • F34R
                            sLaughter
                            • 12376
                            #58
                            That rear panel is awesome, great job!
                            Current cars:
                            ~ '87 535
                            ~ '06 X5 4.8is
                            • DaveG
                              • Nov 2011
                              • 40
                              #59
                              Weekly update time again
                              Got a few bits collected for me in the US during the week
                              Interface for converting the tach signal from the V8 to the correct signal for the 4cyl tach in the cluster
                              Dakota Digital manufactures digital instrumentation and accessories for the automotive, motorcycle and car audio enthusiast.
                              Next is a vent gauge from Podi. It is based on the Alpina designed vent gauge, it can be configured with 4 different read outs , I went with oil temp and pressure,voltage and AFR which will be great to have with Alpha-N to keep an eye on the air to fuel ratio.
                              Can't wait to see this in action. It looks to be a very well made product.
                              Available from www.podi.ca
                              And what it should look like installed
                              Also got a new M3 outer wheel well, this should make things come together nicely
                              The difference can clearly be seen here where it meets the arch,compleatly different profile where it meets the arch.
                              Then modified the subframe steering rack mounts to gain some clearance to the sump
                              Cut off the old mounts
                              Made up some new mounts
                              And welded them on
                              Then made up some subframe reinforcements
                              This is what can happen to e30 subframe engine mount points
                              To avoid this some reinforcement plates can be made up
                              Templates
                              Weld them in underneath
                              Then some plates to stiffen the mounting points
                              And weld them in
                              Used a couple of e39 engine mount to attach the to the subframe to get an idea of what height I needed
                              They're about 60 mm high and are giving me this much clearance to the steering rack
                              Should be able to drop it another 6 to 8 mm if I use good solid engine mounts
                              Mounted the whole lot up on a trolley
                              Cut a lump out of a scrap shell I had for mocking up purposed
                              Snug fit
                              Bulkhead clearance to the water pipes for the heater is tight
                              Lots of fun ahead
                              • ZM Blue Devil
                                • Dec 2006
                                • 13836
                                #60
                                You sure you aren't from Norway?
                                This is in the makings of top 5 build. Great work and documentation.
                                Levent
                                %20levent@gutenparts.com
                                Ladies:
