E30 M3 touring with S62 power
  • I*Do*Werke
    • Dec 2010
    • 259
    #61
    Good progress! Subscribed
    ^M52B28^
    • rav320uk
      • Jun 2004
      • 1337
      #62
      Subbed Dave:D
      If you have bought items from me, please leave feedback below.
      If you are a BUYER, Check My Feedback.:up:
      http://www.r3vlimited.com/board/showthread.php?t=183860
      Check out my Euro Build Thread
      http://www.r3vlimited.com/board/showthread.php?t=215557
      • Kershaw
        • 11822
        #63
        this looks so good. amazing work.
        AWD > RWD
        • CubbyChowder
          • Mar 2012
          • 1487
          #64
          damn, this is going to be insane! Loving this build, subscribed.
          --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
          --Golden Boy E30 Build Thread-- (sold)
          • 89 e30
            • 249
            #65
            Sub'd!
            BIMMER für IMMER
            • Eric
              • 5142
              #66
              Originally posted by ZM Blue Devil
              You sure you aren't from Norway?
              • archie
                • 5448
                #67
                Very very cool!
                88 M3 Diamantschwarz
                89 M3 Zinnoberrot
                56 Isetta
                LIKE ARCHIE'S on Facebook!
                • DaveG
                  • Nov 2011
                  • 40
                  #68
                  Thanks everyone, all the support is great for motivation.
                  • DaveG
                    • Nov 2011
                    • 40
                    #69
                    Another week another bit of progress.
                    One of the main problems in fitting a V8 into an e30 ( amongst many :D ) is the brake servo. There is no room at all in the stock location with a great big V8 stuck in there now.
                    So main options to to extend a pushrod and place the servo behind the headlight. Not a great solution as the rod will have a tendency to flex under hard breaking, it also looks messy
                    Another way to go is the hydraulic system from a V8 e34 or e28. It's a bit complicated for my liking for a braking system
                    A pedal box from the likes of tilton works well but you would loose servo assistance which I didn't want
                    The servo can also be placed in the battery tray position but I can't see a good way of making a linkage that will push in a straight plane to the servo
                    My preferred method is to mount the servo behind the glove box
                    Thanks to Dave the goat on the zone for this idea
                    Here is the original bracket that mounts the servo through the bulkhead
                    Make a plate to now mount it at 90 deg from original position
                    Then reinforce it to stop any flexing
                    Now a Clio servo is used as it is much smaller then the e30 servo as it has a dual diaphragm
                    Mounted in position
                    The fork of the servo has to be drilled and a new arm has to be welded to the swivel arm to push in the right position
                    Here it is bolted into another e30 I have lying around
                    Now I need to get a golf master cylinder as its nice and short and make up some kind of remote reservoir for it. Then it's another job off the long list :D
                    • dude8383
                      • Jan 2005
                      • 10387
                      #70
                      Thats very clever positioning of the booster. Subscribeddddd!
                      • frankie591
                        • Feb 2012
                        • 545
                        #71
                        incredible!
                        • Coyote_ar
                          • Sep 2009
                          • 175
                          #72
                          Great build Dave, keep it coming.
                          Any chance i can have the part number for that Clio servo?
                          ---E30 320i Hennarot 1984 Sedan---
                          • Alpina
                            • Oct 2004
                            • 838
                            #73
                            Very nice ,,
                            the brakebooster solution is absolutly marvelous
                            Sveinbjörn Hrafnsson
                            E30 CABRIO V12 M70B50 ///
                            ALPINA B10 BITURBO 346 @ 507
                            E34 550 V12 JML
                            Finnish wisdom : If you want to Win,, hire a Finn
                            http://alpina.123.is/pictures/
                            • Julien
                              • 7471
                              #74
                              awesome build!
                              Build Threads:
                              • DaveG
                                • Nov 2011
                                • 40
                                #75
                                The servo is fitted to all mk2 clio's. the ones with the plastic wings.
                                Postman arrived with these during the week :D
                                Fook me it was hard taking a grinder to brand new m3 quarters
                                And after
                                Leftovers
                                Cut another bit out of the shell to see how things line up
                                Will there be anything left !!!
                                Only finding more problems for the moment
                                The new quarter meets the pocket much higher up and further in so I will probably have to cut away part of the pocket and make something between the 2
                                Another problem is that the m3 outer wheel well is from a 2 door car and is now coming into contact with the rear door
                                Wheelwell has to go forward about an inch and also up about the same so I will have to cut a lump out of the wheel well
                                Oh the joys :D
