325ic Calypso Euro Conversion - Houndstooth & dbilas now, MT1 & MM 3.2 stroker coming
  • N2MYE30
    • Oct 2007
    • 5536
    #196
    Those are some amazing headers!!!
    COTM
    • bradnic
      • Jul 2012
      • 3554
      #197
      drool is right Dan.. incredible to look at. def hoping I get the chance to own a set.. maybe even an RD valvecover too.
      received @blackjack7s' AFM and sssquid chip today. will be shipping the chip back to sssquid as I have a 173 tune coming from them tomorrow.
      you can see how much bigger they are in the pics below. they're not compatible with the m20 airbox either. I'm sure the E30/BMW vets around here know this cold... but the M30 airbox conversion stuff is new to me, and as usual the OEM+ thing always kicks in..
      the M30 AFM was fully refurbed by Bav Resto last year and looks great.
      the M20 airbox. M30 AFM won't bolt up, and the opening's too small
      M20 vs M30 AFMs - use the same harness connector. M30 taller, same overall length and width
      You see those nuts? That's how all our hardware looked new! zinc chromate plating in my future that's for sure.
      Can really see the opening differences.
      bolt patterns don't line up due to height difference (e.g., left to right in the pic doesn't line up, top to bottom in the pic does). even if they did the housing opening is too small for the M30 AFM
      HOWTOs:
      DB vert plastic bumpers
      OEM Keys
      MTech1 docs
      88 ix Lach/Card
      91 ic Calypso 3.1
      86 Cosmo 2.7
      OEM+ or bust!
      • bradnic
        • Jul 2012
        • 3554
        #198
        Some good info here - 2008! Does anyone really do this old school stuff anymore lol.
        Just don't want to take on a bigger tuning project right now. Alot of changes coming, so 1 step at a time - this is it for the season hopefully.
        and e30tech has plenty of reading.
        stock airbox vs cone filter dyno test http://www.e30tech.com/forum/showthread.php?t=23927
        what dmcl is describes here is what I have in mind, but I need another m20 airbox to hack up first. don't want to mess with my original one.
        similar m30afm in m20 airbox meme: http://www.e30tech.com/forum/showthread.php?t=14419
        as is frequently the case, stock design is pretty darn good. hard to beat without a complete cold air setup. also was of the mind that cone filters don't flow as well but that's a generalization so... no data means it's just an opinion.
        HOWTOs:
        OEM Keys
        MTech1 docs
        88 ix Lach/Card
        91 ic Calypso 3.1
        86 Cosmo 2.7
        OEM+ or bust!
        • bradnic
          • Jul 2012
          • 3554
          #199
          new tune arrived - thanks Jesse! return chip getting posted tomorrow.
          well played on the packaging btw.
          HOWTOs:
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
          • bradnic
            • Jul 2012
            • 3554
            #200
            picked up a spare m20 airbox and modified it for the m30 AFM. Wasn't difficult since the AFM inlet is the same width, just taller. Reused 2 of the holes, extended the opening in the upper airbox piece, and drilled 2 new holes.
            Was also able to keep the air horn / velocity stack by cutting down the center to separate top and bottom. I then trial fit the 2 halves with duct tape (!) and they fit fine - full air flow from a larger cross section. So I filled the gap and JB welded the assembly.
            HOWTOs:
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
            • doorman
              • Mar 2015
              • 360
              #201
              Summer is short as you know bud!!
              Hopefully you'll be ready.
              Looking good so far.
              • bradnic
                • Jul 2012
                • 3554
                #202
                M20 3.1 with RHD ITBs, extensively reworked head
                inspiration via rav320uk and e30zone.
                RHD ITBs are da bomb now. if/when they have an airbox they will be the go to ITB solution.
                EDIT: this *may* be the same car (same color, appears to be right hand drive). has the new RHD plenum installed
                HOWTOs:
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                • bradnic
                  • Jul 2012
                  • 3554
                  #203
                  thanks ;-) yeah I've got TheVintage on my radar. I'll be ready with the following:
                  -- dbilas with a basic stage 1 AFM tune
                  -- 3 new tires (rears + spare)
                  -- painted and mounted eurovalance + new fogs
                  -- new euro bumpers replacing the badly chromed ones on the car now
                  -- install hardtop seals and have the headliner re-glued
                  I also want to replace the decklid to get rid of the brake light wart, but this might have to wait until I get the MT1 installed.
                  trunk's ready :-)
                  HOWTOs:
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • bradnic
                    • Jul 2012
                    • 3554
                    #204
                    380 DME in the car. basically a newer 173, still Motronic 1.3
                    tune is for m20b25, m30 AFM, 19# mustang injectors
                    sssquid motronic 1.3 m20b25-m30-19 chip
                    HOWTOs:
                    OEM Keys
                    MTech1 docs
                    88 ix Lach/Card
                    91 ic Calypso 3.1
                    86 Cosmo 2.7
                    OEM+ or bust!
                    • bradnic
                      • Jul 2012
                      • 3554
                      #205
                      modded afm horn turned out ok
                      this was waiting for me when I got home
                      unpacked - everything was wrapped well and arrived safely.
                      unfortunately these side skirts are not for verts; hoping to trade for repo vert side skirts (or sell them and not run side skirts at all)
                      soda blasted part of the front panel
                      part numbers for the front panel and one of the skirts
                      will put these away for now, but plan is to strip them completely bare, get them repaired and then painted body color. probably leaving the bumpers chrome. Not sure what to do about the end caps since mt1 caps are different and NLA.
                      HOWTOs:
                      OEM Keys
                      MTech1 docs
                      88 ix Lach/Card
                      91 ic Calypso 3.1
                      86 Cosmo 2.7
                      OEM+ or bust!
                      • e30m3s54turbo
                        • Jun 2010
                        • 3290
                        #206
                        Vert MtechI skirts are vary rare.......
                        I like your hoarding parts!
                        • bradnic
                          • Jul 2012
                          • 3554
                          #207
                          indeed.. i'm hoping a certain canuck has pity on me. we'll see.
                          haha not quite up to your quality level raúl, but yeah I already have most parts I need to finish my two E30s...
                          HOWTOs:
                          OEM Keys
                          MTech1 docs
                          88 ix Lach/Card
                          91 ic Calypso 3.1
                          86 Cosmo 2.7
                          OEM+ or bust!
                          • bradnic
                            • Jul 2012
                            • 3554
                            #208
                            anyone need some e32 air vents? they sure as heck aren't MT1s lol
                            what they're supposed to look like, part numbers 51711942967 and 51711942968
                            HOWTOs:
                            OEM Keys
                            MTech1 docs
                            88 ix Lach/Card
                            91 ic Calypso 3.1
                            86 Cosmo 2.7
                            OEM+ or bust!
                            • bradnic
                              • Jul 2012
                              • 3554
                              #209
                              just ordered all the front and rear misc mtech1 hardware, stickers etc., including the air ducts and mysterious lower panels that nobody ever has.. we'll see what's really available from BMW shortly.
                              seems like it's only regulatory/safety affecting and large parts that are blocked from US order...
                              HOWTOs:
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • bradnic
                                • Jul 2012
                                • 3554
                                #210
                                Well that was fast. Every single part is NLA despite being orderable through the catalog.
                                Thank you for ordering from BMW Parts and Accessories .
                                We regret to inform you that the following 21 items are currently unavailable:
                                51711942967 AIR CHANNEL
                                51711942968 AIR CHANNEL
                                51111959739 COVER EURO
                                51111959740 COVER EURO
                                51111919154 LABEL
                                51711953903 TOWING HINGE
                                51121942083 RIVET
                                51121919155 BRACKET
                                51711919169 BRACKET
                                51711926202 BOLT
                                51711926201 8-STRIP EURO
                                51121953905 6 LABEL
                                51121953890 8-BRACKET EURO
                                51111953715 8-FOIL EURO
                                51161881149 8-FOIL EURO
                                51111942081 BRACKET
                                51111942082 8-RIVET EURO
                                51111919151 8-BOLT EURO
                                51711937627 BUFFER STRIP
                                51121932230 BUMPER STRIP EURO
                                51111953713 BUMPER STRIP EURO
                                Reason: Discontinued
                                HOWTOs:
                                OEM Keys
                                MTech1 docs
                                88 ix Lach/Card
                                91 ic Calypso 3.1
                                86 Cosmo 2.7
                                OEM+ or bust!
