325ic Calypso Euro Conversion - Houndstooth & dbilas now, MT1 & MM 3.2 stroker coming
  • bradnic
    • Jul 2012
    • 3554
    #496
    Originally posted by bradnic
    Here's a preview of the hardtop bonus. It certainly looks legit - it even has the same OEM convertible top clamp brackets from the car built in to it. But I can't find a record of that part number anywhere. I don't have my e30 accessories catalog to look through, and I can't remember where I've seen OEM versions of these racks before. Besides there are a couple of decent aftermarket carts out there readily available for < $150 shipped, or even better just setup an overhead lift for the top. Cool novelty factor though
    UPDATE: Turns out there are TWO rack systems in this pile, one of them a 7 piece stand stand pictured in the catalog below, the other a 2 piece wall mount setup that looks like a bed frame. MANY thanks to @jeffnhiscars for helping me figure it out :-). Of course my hardtop storage cover won't work with the storage rack, and the storage cover you need is NLA. You win some...
    So yes as @jeffnhiscars said, it's definitely OEM. Found this in a 1991 US accessories catalog. The part number matches the label.
    [url=https://flic.kr/p/WbTna4]
    EDIT: Note there's a different number for the hardtop cover listed in the US catalog. It's in fact a different cover than that shown on realoem and in the German hardtop winch post earlier.
    HOWTOs:
    DB vert plastic bumpers
    OEM Keys
    MTech1 docs
    88 ix Lach/Card
    91 ic Calypso 3.1
    86 Cosmo 2.7
    OEM+ or bust!
    • c0rbin9
      • Dec 2015
      • 609
      #497
      You need this:
      https://www.ecstuning.com/b-febi-par...211108634~feb/
      Quantity: Two (2)
      1991 318is Brillantrot daily driver (slow restoration)
      • SkiFree
        • Jun 2011
        • 2766
        #498
        Very cool, looking forward to watching your progress on this. I have NEVER seen a hardtop storage rack.
        ADAMS Autosport
        • bradnic
          • Jul 2012
          • 3554
          #499
          Originally posted by c0rbin9
          ha cool to see that.. actually have already replaced my clutch and brake pedal rubber with new bits. go pedal looks a bit dated..
          thanks for stopping by! been following your 02/M20 build for a long time. looking forward to your help with the stroker bits too.
          She's a cruiser, heavy and comfortable. but:
          - I def want more torque, and am def going 3.1.
          - the dbilas ITBs are staying despite their definitely killing midrange torque over the stock manifold, cam and displacement. I can't even drop the clutch and smoke the tires anymore. HP seems to be up though. She pulls well above 4500.
          - Want to keep her civilized, especially smooth idle. I'll def xbrace and strut tower brace the front end, put some bigger brakes on her. I'm never gonna track her though.
          me neither! was genuinely shocked seeing it when it came with @MPoser's new vert. It was also cool to verify it was OEM through the accessories catalog. even more shocking - there were TWO storage racks in the pile, the 2nd a wall mounted version.
          HOWTOs:
          OEM Keys
          MTech1 docs
          88 ix Lach/Card
          91 ic Calypso 3.1
          86 Cosmo 2.7
          OEM+ or bust!
          • bradnic
            • Jul 2012
            • 3554
            #500
            Been chasing electrical gremlins today.
            DRIVER LOW BEAM HEADLIGHT
            Has been refusing to turn on intermittently, ever since before last year's vintage. Cool thing is the check panel low beam warning light reliably tells you if the lamp isn't on. On the way back from the Vintage it turned off permanently. Checked bulb and HID ballast by swapping with right side. both were fine. Swapped out the K4 relay. No change.
            Finally went back to check fuse 13 (LH low beam) and sure enough fuse was dead. Replaced and working now, but this can't be the root cause. Will check euro smiliey wiring mods and grounds again but I don't think I'll find anything. Will just have to wait for it to start failing intermittently again I suppose.
            Other issues I'e been experiencing:
            WASHER SYSTEM WAS NOT PUMPING FLUID. was working perfectly then stopped working.
            BRAKE LIGHT CHECK PANEL LIGHT WAS STAYING ON. intermittently stays on. assume it's related to the 3rd brake light which I'm getting rid of. Will try a resistor across the terminals.
            TURN SIGNAL CHECK PANEL WARNING WHEN LIGHTS WERE ON. If I used the right turn signal when the headlights were on this warning light would come on.
            NONE OF THESE PROBLEMS PRESENT NOW! afaik I haven't done anything other that swap the K4 relay and disassemble the driver side headlight assy.
            Most of this be some related ground or power distro issue in the engine bay. The brake light warning issue is likely separate, and like I've written before I'm swapping the deck lid out anyway so I'll deal with it later.
            HOWTOs:
            OEM Keys
            MTech1 docs
            88 ix Lach/Card
            91 ic Calypso 3.1
            86 Cosmo 2.7
            OEM+ or bust!
            • e30rapidic
              • 2167
              #501
              easier fix is to jump across the two green/black wires at the 3rd brake light wiring harness. You can disconnect the plug behind the trunk side carpet, up by the antenna. This bypasses/tricks the active check system into thinking the 3rd brake light is working as intended. That's how mine is set up.
              Good luck with the other bits, hope they're all easy fixes!
              '87 325ic, powered by S50.
              • kronus
                • Apr 2008
                • 13032
                #502
                I had a similar problem and tore my hair out for a while. Turned out to be real dumb.
                cars beep boop
                • bradnic
                  • Jul 2012
                  • 3554
                  #503
                  thanks Andre. def planning to do this when I swap deck lids and lose the brake light wart. in the interim the brake light check panel warning did come back on once while driving this afternoon. Parked and restarted the car - gone again.
                  Thanks. More annoying than anything really. Swapping out the low beam K4 relay and replacing what looked like a good fuse 13 solved the headlight issue. washer pump and headlamp washers are working again.
                  As of right now everything is working correctly again.
                  ouch kronus! damn. that would have taken a while to track down. only sign would have been a consistent blown fuse. lesson learned for all of us I think - the engine bay gets hot. wondering - did you have the cover over the headlight area at the time or was it open?
                  HOWTOs:
                  OEM Keys
                  MTech1 docs
                  88 ix Lach/Card
                  91 ic Calypso 3.1
                  86 Cosmo 2.7
                  OEM+ or bust!
                  • kronus
                    • Apr 2008
                    • 13032
                    #504
                    Yeah, I run the covers.
                    cars beep boop
                    • pandaboo911
                      • 2070
                      #505
                      Solder doesn't melt until 300F, no way the engine bay is getting that hot. Probably down to higher wattage bulbs or resistance in the connections
                      • bradnic
                        • Jul 2012
                        • 3554
                        #506
                        Good call - thanks for chiming in
                        HOWTOs:
                        OEM Keys
                        MTech1 docs
                        88 ix Lach/Card
                        91 ic Calypso 3.1
                        86 Cosmo 2.7
                        OEM+ or bust!
                        • bradnic
                          • Jul 2012
                          • 3554
                          #507
                          all the MT1 bits are done now except the front valance. still need to build a tool to prep the triple slots.
                          HOWTOs:
                          OEM Keys
                          MTech1 docs
                          88 ix Lach/Card
                          91 ic Calypso 3.1
                          86 Cosmo 2.7
                          OEM+ or bust!
                          • DRVN2WN
                            • Jan 2017
                            • 39
                            #508
                            Nice! Have you mounted the angled tip Stromung? If you posted it elsewhere I've likely missed it since I've not been on the forums in a bit.
                            drvn2wn
                            • bradnic
                              • Jul 2012
                              • 3554
                              #509
                              not yet. parts storage is seriously out of control lol. can't wait to start the stroker phase either, but I don't dare do it til all the other pending stuff is settled.
                              my garage and basement are a complete mess. #wifepatientbutimonborrowedtime
                              HOWTOs:
                              OEM Keys
                              MTech1 docs
                              88 ix Lach/Card
                              91 ic Calypso 3.1
                              86 Cosmo 2.7
                              OEM+ or bust!
                              • bradnic
                                • Jul 2012
                                • 3554
                                #510
                                Flickr test
                                Short URL they provided
                                https://flic.kr/p/XqgXak
                                BBCODE provided (modified with curly braces, highlighted in blue to show the different parts
                                {left bracket}url=https://flic.kr/p/XqgXak]{left bracket}img]https://farm5.staticflickr.com/4377/36374330385_ed79fd5198_b.jpg[/img][/url]{left bracket}url=https://flic.kr/p/XqgXak]callie-shadowline europaint[/url] by {left bracket}url=https://www.flickr.com/photos/bradn/]bradn[/url], on Flickr
                                Parsing all that stuff:
                                includes this Link to the picture page: {left bracket}url=https://flic.kr/p/XqgXak]
                                and this Link to a 1024 wide static image: {left bracket}img]https://farm5.staticflickr.com/4377/36374330385_ed79fd5198_b.jpg[/img]
                                followed by the end of the URL tag, so if you click on the pic it takes you to the Flickr page[/url]
                                there's also this
                                Caption with link back to Flickr page pic name and Flickr user name: {left bracket}url=https://flic.kr/p/XqgXak]callie-shadowline europaint[/url] by {left bracket}url=https://www.flickr.com/photos/bradn/]bradn[/url], on Flickr
                                if you paste the Flickr straight short URL as IMG you get this:
                                If you paste the short Flickr URL as URL you get this:
                                If you paste the Flickr BBCODE as IMG
                                [IMG]callie-shadowline europaint by bradn, on Flickr[/IMG]
                                If you just straight paste the Flickr BBCODE directly you get what Flickr wants you to share
                                If you just paste the Flickr static image part as IMG, without the URL link back to Flickr, you get this
                                That's great, but it's not what Flickr wants you to do.
                                HOWTOs:
                                OEM Keys
                                MTech1 docs
                                88 ix Lach/Card
                                91 ic Calypso 3.1
                                86 Cosmo 2.7
                                OEM+ or bust!
