325ix->540i->325is
  • 325ix
    • Aug 2009
    • 7783
    325ix->540i->325is
    I figured this was as good a time as any to introduce my new car. Over the summer I parted out my ix. I replaced it with a '97 540i/6. That was a fun car, on the interstate once you reached 60mph. At the time I knew I would be getting back into an e30 at some point, I just didn't know when. About 3 weeks ago I was browsing the for sale section and noticed someone was trading an '89 325is and looking for my exact car. After a few calls and pm's I was on my way to San Diego to make the trade and now I am in possesion of an 1989 325is in AWIII.
    My e39:
    The new car, Mila:
    Before anyone asks, yes that is Lambo's car.
    Details of the car:
    -GC conversion with shortened housings
    -16x8.5, 16x9 OZ Futuras with 15mm spacers for effective offsets of et9 and et3 respectively
    -Sparco strut bar
    -Mark D 19lb chip and 19lb Mustange injectors
    -Mtech II wheel
    -Factory wooden shift knob
    -Z3 1.9 shifter
    -Ryan G splitter
    -AW III respray
    -10in. Lukebox
    Plans? I have a Raceskids plate on the way as I have already had a few close calls. I also plan on getting shorter, stiffer springs all around and I need to roll the fenders. The trim will also be going back to black as well.
    This will be my slow project log as well.
  • E30SPDFRK
    • 5709
    Nice dude, looks like a good start. E39's are fun (I have a 01 540i for a daily) but they're not a replacement for an e30. Painting the trim black again will completely transform that car.
    What are your spring rates now? You can raise m20's quite a bit, which would help you out until you get a skid plate. Hell, you might even find you don't need one if you raise it enough.
    Byron
    Leichtbau
    • 325ix
      • Aug 2009
      • 7783
      I'm not entirely sure of my rear rates. The fronts are 440lbs at 6in. tall. All of the adjusters are all the way down. I really want to go a little lower up front. I thought about raising the engine but, I am not really sure how to go about it. Also, I would like to try and keep it as low in the bay to keep from raising the cg, i'm not really sure how much of a difference it makes though.
      • E30SPDFRK
        • 5709
        How much shortened are the housings? That's still pretty high for all the way down with such a soft spring.
        Raising the engine is simple, you either put spacers between the motor mounts and the mount arms/subframe, or you find other mounts that are taller then the m20 ones. It will change the CG slightly, but your CG is lower now then it ever was stock.
        Byron
        Leichtbau
        • 325ix
          • Aug 2009
          • 7783
          Hmm, I may look into that. I assume there is a thread about it somewhere on here.
          I am not sure, I need to see if the PO has the papers on when it was done.
          • lambo
            Captain Scene Points
            • 10953
            How badly does raising the engine affect the angle between the transmission and drive shaft etc.?
            • TimKninja
              • 2131
              Predictable.
              1985 325e M50TU(Sold)
              1991 318is Slicktop (Sold)
              1990 325is Brilliantrot S50/5 Lug Swapped.
              1992 525i Manual shitbox Winter Beater
              • 325ix
                • Aug 2009
                • 7783
                Predictable.
                Huh?
                • Mlarsen
                  • 4082
                  That was my first thought. Looks like an awesome car. How was the drive?
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    Needs less white.
                    I'm snowblinddddd.
                    • 325ix
                      • Aug 2009
                      • 7783
                      Will be less white in a few weeks.
                      • Wh33lhop
                        • 11705
                        I need to turn my monitor brightness down
                        paint sucks
                        • downforce22
                          • Aug 2009
                          • 3192
                          how do the injectors feel on the m20? I bet its way different than the ix without awd and the 540 without the torque
                          • 325ix
                            • Aug 2009
                            • 7783
                            The idle is a little lumpy and I believe this is due to the big injectors. It does feel different. It feels a little slower than Lambo's car but, I chalk that up to the Lukebox and big wheels.
                            • MattAvino
                              • Jan 2011
                              • 2147
                              ahhhh my eyes
                              E30 buildy things
                              http://www.r3vlimited.com/board/showthread.php?t=195286
