325is, Track Ready, Street Drivable, Show Quality
  • randomtask37
    • 3154
    #61
    if anyone hates on a 2jzgte they should shove it. I cant wait to see this. Not only the engine, but the mounting plans. good luck!
    98 M3/4/5
    • IronFreak
      • Dec 2012
      • 3702
      #62
      Your shifter will be in the back seat!
      Instagram @rebellionforge
      • Perry Wilson
        • Sep 2012
        • 528
        #63
        My shifter will be back further... but so will i ;)
        • Eric
          • 5139
          #64
          Originally posted by Perry Wilson
          OK so some people arent going to like but o well. The engine I am going to be doing is going to be a 2jzGTE single with r154 5 speed swap. but im thinking of cutting up the firewall and mounting it behind the front subframe for optimal weight dist. car will run the twins for a little while I save for the single. but in the mean time I can get it running and all mocked up. The power goals are around 600, spooling at under 3500. while keeping weight under 2400. and distribution 50/50
          2JZ-GTE Alone 594 lbs
          With Getrag Six Speed 746lbs
          Good luck getting under 2400lbs!
          Also, why gut the doors and warp your roof when you add a bunch of metal and filler to the engine bay? Seems counterproductive.
          • Perry Wilson
            • Sep 2012
            • 528
            #65
            Ive added less than 30 lbs of metal and filler probably close to 15lbs. A small sacrafice for a badass show quality bay. In case you forgot this isnt just going to be a racecar. And the warped roof wasnt a plan lol it was a mistake i will be fixing. And im not running the 6 speed but thabks for the heads up
            • unevolved
              • Nov 2011
              • 714
              #66
              I like where this is going.
              1991 318i SOLD
              2003 325i SOLD
              Racecars and stuff.
              • Perry Wilson
                • Sep 2012
                • 528
                #67
                me too lol, I guess Im just going to re-engineer the whole car. got to try and get the power to the ground
                • unevolved
                  • Nov 2011
                  • 714
                  #68
                  What suspension work do you have planned?
                  1991 318i SOLD
                  2003 325i SOLD
                  Racecars and stuff.
                  • Perry Wilson
                    • Sep 2012
                    • 528
                    #69
                    well I am already running bc coilovers. but my plan is to ty the cage into all the suspension mounting points. havent gotten that far yet though. time will tell im going to have enough going with the engine mounting fab
                    • IronFreak
                      • Dec 2012
                      • 3702
                      #70
                      I get all tingly when I hear the word fab.....I just want to get up from my desk and go home, fire up the tig and start welding random crap!!
                      • Perry Wilson
                        • Sep 2012
                        • 528
                        #71
                        welding is very theraputic
                        • IronFreak
                          • Dec 2012
                          • 3702
                          #72
                          There is nothing quite like lifting your hood to see a perfectly laid bead on stainless or aluminum with a tig.......ART
                          • Perry Wilson
                            • Sep 2012
                            • 528
                            #73
                            I mig everything and work with steel lol
                            • Perry Wilson
                              • Sep 2012
                              • 528
                              #74
                              pushrod suspension would be badass
                              • unevolved
                                • Nov 2011
                                • 714
                                #75
                                I think you'll be seriously cheating yourself if you spend all the time to set the motor back, move the driver position, and DON'T rethink the suspension.
                                1991 318i SOLD
                                2003 325i SOLD
                                Racecars and stuff.
