323 to 331 Build
  • Saascat1
    • Jan 2013
    • 60
    323 to 331 Build
    Hi all,
    I started a rebuild of an '85 coupe, purchased Nov '11, with the intention of making a "Tarmac Rally" car capable of doing some track work as well. I have been going along slowly and thought I should share my build with other enthusiasts as I've often spent hours on here trawling through tech articles and other peoples threads. I'll try to stick to the timeline for the project as much as possible. Though it must be said from the outset that I did jump about a bit. It is not the most logical sequence for rebuilding a car, but often if was a case of lots of time no money, or money but no time.
    The Car
    Apologies, some of the photos in this thread are taken in different locations as I had to move house halfway, and I use the term loosely, through the project. Also, I didn't take as many photos as I should have and many of the parts are already installed at time of writing.
    I had previously spent some time and considerable money on restoring/improving my E34 525i, (M20B25) and had already waded through all kinds of crap to find what worked and what didn't as well as where to get things. Another story not for this forum. Anyway........
    I wanted this build to still be street register-able from the out set so I had to modify some of my original ideas. I spoke to the local TAC, (traffic advisory council) and placed a proposal for my build with them and then had to wait to see what they decided before I could start. The Modifications proposed weren't that extraordinary, but the MVR can be anal at times about the silliest things.
    The Plan
    Hardcore NA M20.
    Electronics overhaul and update.
    Car stripped to it's bare bones and lightened wherever possible.
    Full 6 point welded in roll cage.
    Racing livery
    and of course Shiny things ;p
    My goal is to try to get 300hp/tonne, and some will scoff. This is not inconceivable given the amount of weight that can be removed, some clever intake mods, a good set of extractors and a hi-flow exhaust, and an ECU and Ignition system up to the task. Ultimately the Dyno and the Scales will tell.
    I have previously read the M20 NA thread that turned into a D@#k measuring contest and would appreciate anyone who wants to get back into that to find something better to do with their time!:hitler:
    Now that that's out of the way............Down to the build.
    After waiting for about three weeks for the TAC to respond I got a letter in the mail saying that I could do as proposed, no exceptions. Good Times!
    The Car I bought was a 323i, and I wanted to go with a 325 as a base, so I bought a Donor motor from a wreckers and set to work.
    Engine Parts
    Ireland Engineering 3.1L stroker Kit.
    H-Beam Rods
    Custom 10.5:1 Ross Racing Pistons and Rings
    ARP Main Bolts
    Coated Rod and Main Bearings
    Aluminium Single Mass Flywheel
    XTR Stage 3, 6 puck sprung clutch
    Aluminium Balance wheel and crank pulleys
    Oil Pan Baffle and Crank scrapper/windage tray
    IE 304deg Cam
    OS Stainless Steel valves
    Schrick Competition Springs
    Heavy Duty rockers
    ARP head studs
    All new valve guides, seals, retainers, collets and eccentrics.
    NB: No I don't have bottomless pockets, I took along time to gather all these bits. I figure if your going to do it, do it once...........do it right.
    I fully stripped the engine and began clearancing the block to receive the 3.1L stroker crankshaft, conrods would hit the bottom of the bore if not clearanced. I also stripped the head as I was replacing the entire valvetrain.
    Whilst I had the die grinder out I also cleaned up the intake runners where they meet the head. The old manifold gaskets had left a very nice impression of where the castings didn't meet up, so I simply enlarged the runners to suit.
    I may have upset the purists here but my thinking was sound. intake is all about getting as much air into the cylinder as possible, laminar flow is the type of airflow, laminar flow is best achieved when the air has as few interruptions as possible. QED
    Once this was was done I sent the block and head to the Machinist Shop along with all my other new goodies for a deck, bore, hone and balance of the bottom end. Straighten, deck, pressure test, then valve guides, seals, springs installed.
    It was never going to be enough to just throw horsepower at the car and expect it to get me onto any kind of winners podium. Stopping and Handling are equally important, if not more so.
    The 323i I bought had the Bilstien handling pack in it from the factory, uprated springs shocks and swaybars, and I really didn't want to change this as a first option. Also after my splurge on the engine, I didn't have the money for coil-overs etc. But that didn't mean I was going to ignore handling either. I noticed that the car had a lot of negative camber, inside edges of tyres bald, outsides near new. This would be fine at the track, maybe, but not to drive any other time. 2.5deg is OK, 5.5 Bad.
    Again I turned to Ireland engineering, they a couple of options for rear toe/camber adjustment, eccentric bolts and plates, or a multi-adjustable set of toothed plates. I went with the latter.
    This of course meant getting the rear subframe out, what better time to replace all the tired old bushes with fancy new urethane ones :)
    Sorry no photos of this process, suffice to say, it was a pain in the.... a very forgettable job that i am glad is behind me. the final result is awesome though. simply loosen the four swingarm bolts and adjust to suit, then tighten. Providing your tabs are welded on the same on both sides, you can easily duplicate whatever settings you want.
    I'll leave the thread here and come back to it soon. I have quite a lot left to go to get up to date.
    Cheers
  • CrJdMc
    • Feb 2012
    • 195
    So much win here, I'm looking to go with the 3.1 stroker kit eventually as well, best of luck!
    sigpicInstagram: bir_madhatter
    Add me on Facebook: https://www.facebook.com/connor.mcco...57?ref=tn_tnmn
    • Saascat1
      • Jan 2013
      • 60
      Cheers CrJdMc.
      I'll definitely let you know haw thing turn out with the 3.1
      • Saascat1
        • Jan 2013
        • 60
        The next phase of the build was actually the disassembly, which co-incidently was also a discovery phase :(
        Got the old motor M20B23 out gearbox and all, dropped Diff and tailshafts and then proceeded to remove the interior. All was going along swimmingly until I pulled the carpet on the drivers side, right side in Australia, and notice a little surprise.
        Yep, that's the garage floor seen through the floorpan.
        I should digress, I bought the car over the internet, flew 4,500Kms to the seller, looked over the car, was satisfied, and after a snappy fluids change, (oil, brake and diff), drove all way home.. The car drove beautifully, the stroked 2 litre had plenty of torque and sat at highway speed comfortably. It had plenty of poke upwards of 130km/h and would accelerate well through any gear. In a nut shell, I was stoked.
        This floor pan issue was the first real obstacle i'd encountered, and to be honest, it had second guessing myself for some weeks. Let me explain: where i live in Darwin, you could count the old Bimmers on both of your hands and still have fingers left. The other issue is the tyranny of distance.. the nearest source for second hand panel etc., is almost 6,000 kms away, at the other end of the country. For a while the problem seemed insurmountable, but fortune smiled and I had to attend a course in the very city that the best wreckers was in :)
        I bought a 1/4 cut for $250, trimmed it down to fit in a box and put it on the plane on the trip home.
        Anyway, the dismantling continued, and the obligatory removal of that crappy tar/bitumen stuff.
Name:	Interior Strip 4.jpg
        I also had a bit of a play with oil pan baffles and windage trays/crank scrappers.
        It was about this time that my Landlord kindly decided to teminate my lease and force me to find alternate lodgings.
        So by this time, almost a year has passed since I bought my new baby, and all I seem to have done is destroy it, the only progress was the rear subframe!, and that was because I had to get it back on it's wheels to move it!
        Yes I know, it could have been worse, worse things happen at sea..............
        Meanwhile.......
        The Machinists had finished with my engine bits. Mmmmm......Engine bits....
        I set about rebuilding the engine, and I have to say this is by far the most rewarding thing I have done. From the sorry M20B25 I had started with........
        I'll pick this back up shortly.
        • dashboardmonkey
          FUCK YOUR WAFFLES
          • Jun 2008
          • 6158
          Can't wait to see a video of this thing running.
          -Andy
          • jules325i
            • Jul 2011
            • 353
            Good to see another aussie stroker.
            I'm thinking of selling my brand new megasquirt engine management system, and looking at your serious build it would suit you very well.
            329i
            • Saascat1
              • Jan 2013
              • 60
              Thanks for the comments. I was thinking of going with an EMS ECU and MSD ignition with a distributor delete as well as MAF. Using a MAP sensor and magnetic pickup on the cam gear. Do you think the Megasquirt would handle this? If so PM me with a price I'm definitely interested.
              • Saascat1
                • Jan 2013
                • 60
                Some Photos of the Engine........
                All surface rust removed before install. These parts were from Ireland Engineering and are fantastic. It should be noted though that some minor modification was required for the oil pan baffle. I'd also recommend test fitting a few times before using gasket adhesive and final install. I, and my lovely blue motor, got covered in the shit before I got a got method worked out. Then got covered all over again trying workout why it didn't fit first go! Oh well, lesson learnt. I also recommend using two gaskets although it is fiddly getting all the holes to line up.
                And finally............
                I still need a few odds and ends to finish the motor, peripherals mainly, so I put a cover on it and have moved on to the steering, sway bars and body.
                More to come.
                • Saascat1
                  • Jan 2013
                  • 60
                  That makes two of us Andy.
                  I'll b sure to post Video as soon as I get some. :up:
                  • dashboardmonkey
                    FUCK YOUR WAFFLES
                    • Jun 2008
                    • 6158
                    "like"
                    -Andy
                    • evandael
                      • Oct 2009
                      • 2881
                      awesome engine build :up:
                      • e30m3s54turbo
                        • Jun 2010
                        • 3265
                        I like early e30 projects. Nice car.
                        • MattAvino
                          • Jan 2011
                          • 2147
                          real purty
                          E30 buildy things
                          http://www.r3vlimited.com/board/showthread.php?t=195286
                          • Saascat1
                            • Jan 2013
                            • 60
                            Thanks All for your kind words.
                            Once I had put aside the motor for now, I rearranged the area under my house, read "garage" and got my pride and joy out into the middle so I could get to work.
                            Up onto stands, wheels off and then tie rods disconnected, front sway bar disconnected, control arms removed, struts removed and finally, subframe out.
                            I had purchased a seal/rebuild kit for the power steering rack and took it to be rebuilt.
                            Now to see about re-enforcing the subframe.
                            • Saascat1
                              • Jan 2013
                              • 60
                              IE to the rescue, again. sourced swaybar reinforcing plated and HD swaybar brackets, and with the help of a good mate got to work.
                              Also bought their motor mount reinforcing plates. These had to be modified slightly to get a good fit in the subframe itself, and then the holes provided for acces to the motor mount needed to be opened up a little with a die grinder to allow a socket in.
                              The finished product:
