E36 M3 - LS3/TR6060 Swap
  • jakeb
    • 1909
    #256
    Intake pipe all welded up
    Went to start it yesterday but didn't have much luck. Fuel pump was running, good fuel pressure but the plugs were bone dry. A little digging and asking some people and I found out I needed to disable a starter diag in the tune. Changed that did a write entire on the tune....and bamn!!
    There is a *slight* exhaust leak at one of the vbands off the header. Just needs to be tightened up a bit more.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • GreasyE30
      • Dec 2012
      • 159
      #257
      Wow fuck yes!!! That's awesome!!! Beautiful car with a beautiful swap! Sounds good as well :thumbsup:
      2006 Dodge Magnum SRT8
      1986 Slammed Shwarz ETA Coupé (DEAD)
      2004 Slammed TSX A/T (Wifey's)
      1963 Slammed ChevyII never ending project
      1982 Suzuki GS1100GK CaféRacer
      • Galicianslash
        • Apr 2008
        • 40
        #258
        Heeelll yeeeah!!! Awesome job man!
        • E30 Wagen
          • Jul 2005
          • 3434
          #259
          I'm really digging the fender work.
          Sorry if you've answered this but where is the customer from? A guy around here saw i was into BMWs and told me about a friend of his who was having a LS engine swapped into a M3. Wonder if it's the same guy.
          My Feedback
          • jakeb
            • 1909
            #260
            Customer is not in Michigan...or even all that local.
            • blunttech
              • 12850
              #261
              Awesome work as usual. Get that other one done and lets do an S85
              sales@blunttech.com
              www.blunttech.com
              Like us on Facebook
              • ACHTUNG
                • May 2005
                • 2397
                #262
                Wait, wait! Before you start the next one I need some headers and a harness! Money coming your way tonight! :)
                1989 US E30 Cammed S52
                Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                • jakeb
                  • 1909
                  #263
                  Wrapping up little things before it's first drive.
                  Made a front and rear strut brace and had it coated.
                  Had the intake pipe coated
                  Bleeding the brakes and clutch today took hours......just lots of air to get out. But all is working now as it should.
                  My little guy was out in the garage and wanted to check out the beast. He had some wrenches in his hand but it was hard to get a pic as he moves quickly.
                  • ACHTUNG
                    • May 2005
                    • 2397
                    #264
                    Are you respraying it or is the owner going to do it (or have someone do it)?
                    • jakeb
                      • 1909
                      #265
                      A big chunk of it will get repainted here. My cousin is doing most of the body work. I did the welding and fitting and he is doing all the finish work.
                      • ACHTUNG
                        • May 2005
                        • 2397
                        #266
                        Nice...
                        • jakeb
                          • 1909
                          #267
                          The plan was to drive it today but it has been raining ALL day here. The flares don't have paint on them so I really don't want to get water all over the flares before paint.
                          Hoping it stops tomorrow so I can drive it. Even just around the block.
                          Still worked on some things...the little jobs take time as well.
                          Installed a volvo pusher fan in the BMW shroud. Pushes a TON of air.
                          Mounted the trans cooler for good. Bracket back from power coating.
                          Clearance between the bracket and fan.
                          I had the BMW coolant temp sensor turned down from the stock M14 size to M12 to fit in the LSx head.
                          Where it lives....there is a BMW 2 pin connector that goes on the sensor. Just not connected in the pic.
                          I wasn't very happy with how the caster was ending up with the bimmerworld fcabs...they are set inside and it was pushing the wheel too far forward. While it was clearing everything it just wasn't right. So I switched from the offset bimmerworld fcabs to a centered bushing from condor speed.
                          Fitment before...
                          After...much better
                          Been also doing finish work on the flares. I'll snap some pictures tomorrow of them.
                            • 37834
                            #268
                            Congrats! Sounds great too! Can't wait to hear it rev up.
                            Grover Beach, California
                            BimmerHeads.com
                            • jakeb
                              • 1909
                              #269
                              Self etch primer on all the bare metal spots.
                              Flares now have the first coat of high build primer
                              Engine bay almost done.....
                              • giantkeeper
                                • Aug 2009
                                • 1416
                                #270
                                Sooooo tasty! Great work Jake, I honestly wish I could do more of this rather than corporate world stuff!
                                Always Always go for the reach around if there is an option
