E36 M3 - LS3/TR6060 Swap
  • jakeb
    • 1909
    #226
    Looking so nice in the freshly painted bay
    Today was spent building the exhaust...
    X-pipe into Spintech
    Sure is fun to tig...
    From the headers it goes to magnaflow metallic cats, X pipe, then a spintech
    Back half...at the back of the car before the tips is a dual in dual out magnaflow.
    This was the LAST piece that went in to make it all work. Had to do this runner a few times before I was happy with it.
    I must say this is the BEST exhaust system I have ever built. I am blown away every time I look at it. REALLY happy with how it all came together. I wish I had some hangers to get some better pictures rather than things being held up with jacks, etc. Next step everything will be fully welded. the two pipes from the spintech to the magnaflow need to be welded apart from the system as they are pretty close to each other in a couple spots and won't be able to get the tig torch in there. Everything will get fully welded then go back up and hangers will be added. Along with the tips.
    Shooting to be firing her up next week.
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
      • 37834
      #227
      Originally posted by jakeb
      Yup it is a spintech, they are awesome!
      I had a feeling!
      The exhaust work looks incredible man. Be proud of it!
      Grover Beach, California
      BimmerHeads.com
      • Galicianslash
        • Apr 2008
        • 40
        #228
        this build just keeps getting juicier! can't wait to hear what it sounds like
        • jakeb
          • 1909
          #229
          Went up north to the lake for a little bit this morning with the fam. Got home and my son was ready for a nap so I had some time to do some welding.
          These are the two pipes that go from the center muffler to the back of the car...all welded now.
          Center section off the car ready to be welded up.
          Welding sure is like meditation.....
          • F34R
            sLaughter
            • 12376
            #230
            1+ I get so much thinking done while welding. It is soothing after you learn what you are doing! Awesome job Jake.
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • jakeb
              • 1909
              #231
              Center section all welded
              Entire system put together and hangers added
              Tips
              Entire thing off the car...few joints to weld up
              Remote clutch bleeder
              Fuel pressure filter/regulator (still needs hose clamps)
              Top ring on the shifter carrier is to hold the shifter lever in place.
              • stanhayward
                • Mar 2013
                • 765
                #232
                Looks like quite the sleeper exhaust there, those tips look stock! Really nicely done
                1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
                1984 316 Coupe - The Base Model - Pain in the Ass
                1988 750iL - The Daily Driver
                ...And a couple others...
                • evandael
                  • Oct 2009
                  • 2881
                  #233
                  you're an artist.
                  • GreasyE30
                    • Dec 2012
                    • 159
                    #234
                    Yea x2 on the exhaust looking OEM, in a good way. Well done! I bet it won't sound OEM lol
                    2006 Dodge Magnum SRT8
                    1986 Slammed Shwarz ETA Coupé (DEAD)
                    2004 Slammed TSX A/T (Wifey's)
                    1963 Slammed ChevyII never ending project
                    1982 Suzuki GS1100GK CaféRacer
                    • F34R
                      sLaughter
                      • 12376
                      #235
                      OEM looking exhaust? That is a slap in the face for Jake... :) That is fitment perfection with sexy tig welds.
                      Current cars:
                      ~ '87 535
                      ~ '06 X5 4.8is
                      • jakeb
                        • 1909
                        #236
                        haha, it is better than OEM but looks like it came from the factory this way.
                        It's a big time heat wave here but I have a couple of AC units in the shop and it keeps it workable but temps still climb.
                        The list is getting shorter. Engine will be back in for the last time tomorrow...suspension will get finished up. Shooting to start it Tomorrow or Thursday (more likely)
                        Header on for the last time, subframe on loosely.
                        Clutch line off tr6060
                        Clutch connection from BMW hardline
                        Front right flare needs one more sanding and then some finishing filler before primer
                        Right rear flare really close as well.
                        • jakeb
                          • 1909
                          #237
                          ABS Pump in place...
                          etending the wires in progress
                          Done
                          Last time it will have an empty bay
                          Engine In
                          Front suspension all on
                          Brakes going on
                          Had to put a wheel/tire on just to see how they fill them
                          This is will full negative camber...won't run like this but wanted to see what it looked like.
                          Finish filler on the left front flare
                          Right rear flare just about ready too.
                          • Vtec?lol
                            • Dec 2009
                            • 3278
                            #238
                            Sekksie!!!
                            • stanhayward
                              • Mar 2013
                              • 765
                              #239
                              Originally posted by Vtec?lol
                              Sekksie!!!
                              ^ this plus 1
                              • 303e30
                                • Feb 2012
                                • 71
                                #240
                                Wow this is an amazing build!
