r3v's least popular swap - turbo diesel into db vert - slowly
  • MAXELHOFF
    • Jan 2008
    • 414
    Still doing research. I do not know a lot about diesels. 4 or 5 speed for sure. Suggestions and thoughts welcome.
    1997-1999 turbo VW Jetta AHU diesel- Very few wires needed to run.
    9.88%
    8
    1987 Mercedes Benz 2.5L turbo diesel- Very few wires needed to run. Available in longitudinal setup.
    34.57%
    28
    524td bmw diesel M21- Not the best diesel. "Fits."
    29.63%
    24
    2003ish VW TDI- Plenty of wiring. Key and gauges needed to run...etc. $.
    11.11%
    9
    OTHER turbo diesel engine- Please elaborate.
    9.88%
    8
    rob
    12.35%
    10
    grain of salt:p
    http://https://youtu.be/H8gOAzYchAE:ot:
  • MAXELHOFF
    • Jan 2008
    • 414
    clean and wet
    Idles perfect. It has been a great engine. NO issues in 6-ish years. Rev-limiter tested. Water-pump started spraying. Time for the timing belt anyways. Decided to go diesel while I have another vert to drive.
    grain of salt:p
    • MAXELHOFF
      • Jan 2008
      • 414
      dirty dirty
      D
      grain of salt:p
      • MAXELHOFF
        • Jan 2008
        • 414
        Ready to be hoisted
        grain of salt:p
        • CoreyZ
          • 384
          I'd say the 524TD, just because I'd like to see what can be done with one
          • LJ851
            • 7918
            Need more info to make the correct choice.
            1) fuel mileage
            2)Horsepower and torque
            3) Transmission options or lack thereof.
            Thank You.
            Lorin
            The M30 is God's engine.
            • Perry Wilson
              • Sep 2012
              • 528
              just drop in a big ol turbo cummins
              • CrusherCurtis
                • 2532
                God, the m20 has to be one of the worst cosmetically wearing engines.
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  maxelhoff, you are a weird son of a bitch, I will tell you that much.
                  2014 Alpine White 335i MSport
                  (Daily Driver)
                  Full Mperformance Aero
                  KW V2 Coilovers
                  VRSF Catless Downpipes
                  • evandael
                    • Oct 2009
                    • 2881
                    do the om602 turbo, with the w201 2.6 5-speed (if you can find one) and an S2.93. i'm sure it'd be fun.
                    also, get the mechanical pump built up, an external wastegate, and a big exhaust, then crank the boost and watch your EGT gauge. torrrrrrque.
                    • TimKninja
                      • 2131
                      The E30 came with the 524TD's engine in europe. Its been done many times. I think the 260 will bolt right up.
                      Next winter im seriously considering assembling a beater E30 eith the M21 turbo Diesel. 40 MPG Diesel goodness.
                      1985 325e M50TU(Sold)
                      1991 318is Slicktop (Sold)
                      1990 325is Brilliantrot S50/5 Lug Swapped.
                      1992 525i Manual shitbox Winter Beater
                      • AbsorbantNut
                        Non faccio funzionare questa merda
                        • Jun 2010
                        • 2491
                        524td ftw!! There was one for sale localy a while back. You should do that for sure!! I'm pretty sure they did sell 324td's in Europe as well. You could upgrade the Turk to a holset and call it a day!
                        '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                        • Herr Faust Schinken
                          • Feb 2012
                          • 3580
                          i think its just because its almost all metal and most M20s leak a bit so when they leak the oil gets burned on, also cosmolean that dealer ship used doesn't help the situation. if you just wash the motor with pressure washer and/or degreaser they clean up alright
                          88 325is Five Speed
                          Lachssilber
                          • F34R
                            sLaughter
                            • 12385
                            524td swap!
                            Instagram: @BWeissLeather
                            Current cars:
                            ~ '87 325 M30B35 swap
                            ~ '87 535
                            ~ 01 540 Msport 6spd
                            ~ '06 X5 4.8is
                            • iXguido
                              • Nov 2009
                              • 721
                              m21! Do it!
