►►►Tales from IronFreak and his shop shenanigans◄◄◄
  • IronFreak
    • Dec 2012
    • 3702
    #166
    The final part needed for my suspension showed up Friday!
    Thinking about taking a half day this Friday and going to town on the car. Finish stripping the undercoating, stitch welding. Build the coilovers, replace ball joints, reinforce the front subframe and finish pulling apart the rear trailing arms to reinforce, install new bushings, clean up the half shafts, pull apart the Diff. for a little overhaul. I want this on the ground by the first part of May!
    Instagram @rebellionforge
    • MattAvino
      • Jan 2011
      • 2147
      #167
      Sweeeeet
      E30 buildy things
      http://www.r3vlimited.com/board/showthread.php?t=195286
      • kingston
        • Jun 2010
        • 2669
        #168
        Alright Ross!! Sounds like a great plan, man!!
        Originally posted by LJ851
        kingston is the play by play announcer for this thread.
        ‘Tis by the grace of God that my cars run!
        Originally posted by unloadedak
        #teamross
        Siobhan's Build Thread - UPDATED!
        • lambo
          Captain Scene Points
          • 10953
          #169
          What rates did you go with? I see 750R.
          • IronFreak
            • Dec 2012
            • 3702
            #170
            The fronts are 525lbs. I was going to go with the 550, but they were on back order and Trevor at gc wasn't sure when they'd be in. we'll see his this holds up. I now have the aluminum heads, and just ordered a new aluminum intake that is lighter then the stock so I won't be supporting as much weight as I originally thought.
            • ballski
              • Jun 2012
              • 345
              #171
              gimme those heads
              Current Moneypits: e36 m3/4/5 Turbo Techno
              1961 Cadillac deVille bagged -
              IG @bryang513
              • lambo
                • 10953
                #172
                What shocks are you using?
                • IronFreak
                  • Dec 2012
                  • 3702
                  #173
                  Koni's, I'm going 5-lug so I got the cut-n-gut inserts. koni's in the rear too, although I'm thinking about selling mine and going with the 77' Porsche 911 shocks. They have external adjustment......not sure if it's worth the price though.
                  • IronFreak
                    • Dec 2012
                    • 3702
                    #174
                    Originally posted by ballski
                    gimme those heads
                    Haha, you had you're chance!
                    I'll do a trade on you're wheels ;)
                    • lambo
                      • 10953
                      #175
                      I know this is kinda random, but if you haven't...get the gc tall rsm's. My friend has them on his car and they're awesome! I definitely plan on a set this summer.
                      • IronFreak
                        • Dec 2012
                        • 3702
                        #176
                        I already have the turner motorsport mounts....
                        What is the advantage of the tall mount?
                        • JCarp90
                          • Feb 2011
                          • 1759
                          #177
                          moar low?
                          • IronFreak
                            • Dec 2012
                            • 3702
                            #178
                            I don't think thats going to be an issue. Plus my cars first priority is performance, I could care less about getting low as possible. If it handles well that's what matters. I need to make sure my shoes fit.......
                            • lambo
                              • 10953
                              #179
                              Not really more low... The springs won't drop out when you lift the rear of the car. It's quite nice, actually. But if you have some already, then I wouldn't bother.
                              • IronFreak
                                • Dec 2012
                                • 3702
                                #180
                                Ah nice! I was going to make some tie-down brackets that would attach to the shock mounts, figured I could always do a limit strap to the chassis to help eliminate that problem too.
