►►►Tales from IronFreak and his shop shenanigans◄◄◄
  • IronFreak
    • Dec 2012
    • 3702
    #241
    So I got out of class a little early last night, it was to nice out not to get in a few hours in the garage! When I walked in the door my new throttle body was sitting on the couch!
    Then out to the garage where I took my sand blasted tubes and started to weld up the sleeve stops!
    I got them painted and one of them completely assembled!
    Ignore the faded paint on the strut tube it'll get fixed. the nozzle on the can got plugged and I didn't have another one. I didn't get the second of done either........after I got the shock inside the tube and tried to thread the bolt I realized that the threads inside the bottom of the shock were a little messed up. Instead of forcing it....(thanks Adam) I decided I'd just get the proper size tap and chase the threads. Should be done tonight!
    Instagram @rebellionforge
    • IronFreak
      • Dec 2012
      • 3702
      #242
      Suspension Weekend!
      Well I have a few updates.....it's lacking in pictures though.....my computer crashed yesterday and all the pictures from my camera are on there. This is what I had on my phone.
      Well Saturday I started off putting together a set of front coils together for a local dude, they turned out well.
      Then I got back to mine and finished them up! I'm super stoked on how well they turned out. All I have to do now is modify the top strut mount to fit the e28 camber plates.
      Again.....I apologize for the crappy cell pictures.
      I also worked on the from subframe. I have a load of pictures on how I did what I did, but they are inaccessible right now. Maybe I'll update this later if anyone is interested.
      From the above shot you might not notice much but all the unwelded seams are now welded on the motor mount point. I also reinforced the mounting surface on the underside with an 1/8" plate.
      I then boxed in the bottom and sides and drilled an access hole.
      A little more clean up and paint and she'll be good to go.
      Hopefully this weekend all the suspension will be on.....minus the rear shocks. I ordered 1977 Porsche 911 twin tube external adjustment shocks from Koni....they are out of stock in the states until mid June. I'll be borrowing some from a buddy to transport the car to my new shop.
      More to come!!
      • kingston
        • Jun 2010
        • 2669
        #243
        Jeez, you weren't messing around on the front subframe!
        Originally posted by LJ851
        kingston is the play by play announcer for this thread.
        ‘Tis by the grace of God that my cars run!
        Originally posted by unloadedak
        #teamross
        Siobhan's Build Thread - UPDATED!
        • IronFreak
          • Dec 2012
          • 3702
          #244
          I also got some other parts over the last few days!
          Kamotors sent me a set of his brand new ULTRAWIDE flares!
          Massive Lee sent me a booster delete kit!
          And the ever so kind Mr. Levent at GPS sent me a fuel tank!!
          Lots of goodies.....my parts room....well it's running out of room!!
          • kamotors
            • Nov 2007
            • 7102
            #245
            yay
            7speedshop.com
            • IronFreak
              • Dec 2012
              • 3702
              #246
              Originally posted by kamotors
              yay
              Dude, FLAWLESS execution on these things!! I will rock with pride and post up pictures you can use for your thread....Thank you so much for taking so much pride in your work, it shows!
              • Lof8
                • Oct 2006
                • 2827
                #247
                I'm looking forward to the pics. I've been eyeing the KA flares for a while. I'm just trying to justify the cost of a whole new wheel/tire setup.
                S50'd
                Originally posted by TDE30
                What is this faggy shit I have happened upon?
                I can always live in a M3. Can't M3 a house.
                • IronFreak
                  • Dec 2012
                  • 3702
                  #248
                  I know that Kamotors is going to post of some pictures later this week, if you're patient I will have mine on possibly late June depending on how the rest of the build goes. I will burn a couple weekends moving the shop so that will set me back a bit. and I have to take some time to build a pipe bender for the cage...
                  • kingston
                    • Jun 2010
                    • 2669
                    #249
                    Well, start putting the parts on the car, then!
                    #teamross
                    • IronFreak
                      • Dec 2012
                      • 3702
                      #250
                      Got a little bit more done this weekend. Started by undercoating everything, well almost everything. I didn't do the far back section as I have some other plans and I left the tranny tunnel untouched as I think I may have to modify to fit my transmission. I used Delphin EB-41 Polyurethane paint. It's lite, crazy durable and oil resistant!
                      I ended up going with the Bimmerworld CAB's, basically the same as treehouse and you can also replace the bushings in these.
                      Bolted those and the control arms on.
                      Bolted in the E28 camber plates, will do a little modification to the strut towers after I get the car moved.
                      Bolted in the suspension.
                      representing yo!
                      Suspension on!
                      Rebuilt M3 rack in. Need to get bigger zip ties for the inner portion of the boot.
                      Rear subframe and Diff mounted.
                      And that's where I stopped. My buddy had borrowed my subframe and I didn't get the bolts back for the trailing arms so I could't get those on. I should have it rolling this week. and have it moved to the new shop next weekend. All the suspension will come back off as I have some odds and ends to finish up, but it was fun to actually be able to bolt stuff onto the car!
                      Stay tuned!
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        #251
                        Eeeeieieiiiieeii!!
                        I love the rotisserie action here! Having a lift is one thing. Having a rotisserie....man, gotta get one of those.
                        • IronFreak
                          • Dec 2012
                          • 3702
                          #252
                          Its made everything really easy to bolt on, I even did the diff by myself, all waist high, no crawling around on your back or need for jacks. I'm getting excited. it should really start to come together over the next couple of months!
                          • FunfGan
                            • Jan 2011
                            • 4958
                            #253
                            Man, this is simply amazing. I hope that my build can be on the level of yours one day :crazy:
                            Needless to say I absolutely cannot wait to see this together.
                            Go here be happy!
                            Ratchet Garage e30 V8 build.
                            • IronFreak
                              • Dec 2012
                              • 3702
                              #254
                              Thanks! I'll get it moved next weekend, it'll go back on the rotisserie for a week at the most while I finish a few things up underneath. Then motor work starts and cage design. I'm hoping to have the motor fitted by the end of June as well as the cage.
                              • IronFreak
                                • Dec 2012
                                • 3702
                                #255
                                The Beast only comes out at night...........
                                Well I spent some time in the garage last night.
                                Got the trailing arms and axles bolted up.
                                Then I pulled it off the rotisserie
                                Got the fenders mounted up for the move
                                Then the doors
                                Borrowed at set of rotors and DS2 from my buddy
                                Very rarely ever seen in this condition the Beast only leaves it cave after dark......
                                Bolted the hood on
                                Then I cleaned the mess I made in the garage over the last couple of months.
                                Packing up all the parts tomorrow night, moving the car Saturday!! I was over at the new shop last night clean up as well......SO MUCH MORE ROOM.
                                Gunna get crazy.......
