85 Euro 320i Tranforms (Hartge H35) + H bomb
DSC04926 by Raul Salinas, on Flickr
DSC03413 by Raul Salinas, on Flickr
Smilie headlights Ehh......:DYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
If you have bought items from me, please leave feedback below.
If you are a BUYER, Check My Feedback.:up:
http://www.r3vlimited.com/board/showthread.php?t=183860
Check out my Euro Build Thread
http://www.r3vlimited.com/board/showthread.php?t=215557Comment
Extreme caution spling the adjustable headlight regulator as the the tube that joing with the adjuster is hard pressed only and the plastic isn't stout and could result in damage. One of my two e30 M3's euro restorarion resulted in a broken connection with the adjuster because was laying arround (already spliced) in the engine bay and engine and other stuff wasn't finished, somehow it broke up! Now just one headlight is what adjust actually. Kinda lazy to buy another one specially if you never DD the car and carry weight in the back to keep the headlights adjusting the position.
The Hartge left exhaust tip looks beefier, where is going H35 or H35-24?
Nice touch up of the valve cover.Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
Rav soon I will order a set from you. Do you have a e21?
Thanks, Diego.Extreme caution spling the adjustable headlight regulator as the the tube that joing with the adjuster is hard pressed only and the plastic isn't stout and could result in damage. One of my two e30 M3's euro restorarion resulted in a broken connection with the adjuster because was laying arround (already spliced) in the engine bay and engine and other stuff wasn't finished, somehow it broke up! Now just one headlight is what adjust actually. Kinda lazy to buy another one specially if you never DD the car and carry weight in the back to keep the headlights adjusting the position.
Thanks for the tip on head light adjusters.
Not sure witch Hartge exhaust tip is going on the H35.
On the Hartge valve cover it took a few hours to make it look nice.
This came in on Friday. It is a selector rod for my shifter. It looks awesome. The welds look great. Zach (chance on r3v) made for my m30 swap.
Thanks Zach!:up:
Im just honored it is sitting on the same table as all those epic Hartge parts, much less going on the same car!Comment
Yes it may be beefy. I am sure will not fail under hp stress to come.
I feel the same. My welds don't look like that. He did awesome job. I am glad you sold your e28. It was tempting.
Thanks, Zach
I can't wait to try it out.Projects Hartge,Alpina & AC Schnitzer Builds.http://www.r3vlimited.com/board/showthread.php?t=280601
Here is a Alpina big brake kit. The kit is not complete. I am going to use a 750il master. The brake lines I will make.
This is my second set of Alpina big brake kit I bought. The first I installed on my Hartge H26. Hartge big brake kit is so very rare hard to find. Hartge did not sell as much as Alpina did. There is no differance between Hargte and Alpina big brake kit. The only thing that is staped is the rotors. One big brake kit would say Hartge or Alpina on rotor.
Oh man that is awesome! Are those rotors something you can buy easily or are the specific to the alpina/hartge kit?Comment
I was wrong about the Hartge and Alpina rotors being the same. They are different. The Hartge cooling fins are on back side of rotor. I think the Hartge rotor is a better cooling system.
The Alpina's cooling fins are front of rotor. The calipers and master are the same.
I took some pics starting to the left is e36 M3 rotor, middle Alpina rotor and right side e30 M3.
Side to side L Alpina rotor and R e30 m3 rotor.
Another rare piece I never knew existed! So cool. :)Comment
I just picked up a set of these brakes, the last component I need to have everything 'factory'. I'm not putting them on the car as the 4 pots going on will provide better stopping power and with a care so rare, I'm keen to be able to stop quickly.
Also picked up an Alpjna C2 recently, might fit them onto it :-)Hartge H35
Alpina C2.5
325i cabriolet
325ix laser blue
And many more.....Comment
