The not-so-fancy making of a vert
  • cmeptb13
    • Apr 2011
    • 121
    Yea it just gonna be a stock size K&N filter. And the snorkel will be set up same as a stock behind the headlight.
    I just needed to cut a bit out of the bottom of the airbox so that it doesn't interfere with the alternator. And then used some aluminum to make a new bottom. It doesn't change anything for where the filter is sitting.
    And I've cut a round hole instead of the original rectangle so it doesn't bottle neck.
    • cmeptb13
      • Apr 2011
      • 121
      Originally posted by AbsorbantNut
      So do you have a filter in that stock airbox anywhere?
      • cmeptb13
        • Apr 2011
        • 121
        Quick update:
        So I'm yet to take the car for a test drive. I've spent the past few days trying to figure out the last touches on the swap.
        First I wanted to have the shifter centered and I've used this e30performance write up as a guide:
        No hating, but it just seems too slopy to do it this way:
        So after cutting the shifter carrier and grinding it down to fit the 3/8" square steel tubing (from home depot) I've realized that all I had to do was flip the half of the carrier and I'd be home free.
        And there you have it boys and girls. It's so easy a cave man could do it.
        I had to tweak it a little bit so that everything fits perfectly. But now my shifter is centered and no interference. I'm happy.
        And so I've spent this evening reinstalling the driveshaft, which was kind of a bitch.
        Anyway another update's coming up, once I'll take her for a spin around the block.
        • cmeptb13
          • Apr 2011
          • 121
          WELL! Tonight it's official. My friend and I took it for a spin, just the way you see it in the pictures, and it was a BLAST! I'm so excited I'll have to hustle to wrap things up so that I can actually drive it on the street.
          Everything's looking good so far. Except one thing I've noticed is the steering kind goes bump-bump-bump... Could it be from the air in the system???
          • Garageaholic
            Freestyle Fabricator
            • Dec 2005
            • 5204
            Shifter sits nice and center. Just make sure you locktite that hardware on that shifter.
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            Instagram.com/garageaholic
            Youtube.com/garageaholic
            • F34R
              sLaughter
              • 12376
              LOVING the block man, so clean :)
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • mr2peak
                • 2388
                Is that an Mtech 2 kit as well? Hard to see in the first post
                Drive it hard. Maintain it well.
                A Topless Memorandum
                • cmeptb13
                  • Apr 2011
                  • 121
                  Thanks guys. And yes Mtech 2 vert with a manual trans and a hard top. It's all in the making. You'll see... heheh
                  • Habla
                    • May 2004
                    • 1470
                    Love your shifter solution!
                    -Peter
                    318is slicktop | F15 35dM | F250 SD
                    • unloadedak
                      • 1197
                      hey man. i used solid mounts on that cross member. never saw angles like that. that's kinda weird. I never had an issue, sold it because ZF.
                      2003.5 Imolarot M3: daily
                      1995 Alpinweiß M3: hpde
                      • cmeptb13
                        • Apr 2011
                        • 121
                        Yea I'll just get another cross-member from one of the people on this forum.
                        • cmeptb13
                          • Apr 2011
                          • 121
                          I know how low of an expectation most of you have, so I didn't want to disappoint you.
                          However, the not-so-fancy vert may have gotten a little fancier.
                          Not too bad for a rattle can job. Please note that I've only added the e36 lip to try and fix that warped m-tech valance. It's aftermarket so the fitment is shitty, but I knew nothing about it back when I'd bought it. Just trying to make it work and it has proved to be a challenge.
                          On the other hand I did get a Nardi steering wheel from the German ebay
                          However, I have been waiting for the Scorpion exhaust from the BavAuto sinceMay 20th, so it's been almost three months. If I would've know I'd get it through eBay.
                          Don't expect any updates any time soon.
                          Not before the exhaust is done.
                          • BustingMyWallet
                            • Jul 2013
                            • 14
                            The reason I love this thread is because you're doing it right. Everything is practically OEM, and brand new. And the parts that aren't new, are so clean that they look new. Really good build. I love the originality with the gold on the engine block.
                            • lambo
                              Captain Scene Points
                              • 10953
                              Yeah "not-so-fancy" my ass!
                              • NeedaE30
                                • 397
                                <---Jealous
                                Must get garage.... must get garage.... i need a damn garage...
                                nice build..
                                any updates? been a while
