318 reborn into e30 335
  • jekaio
    • Jun 2008
    • 89
    #91
    i'd be down possibly for a DSSR.
    if you know you have a problem with the plug wires, change them.
    and if you have yet to check your valve clearance, that should have been one of the first things after startup.
    • chance
      • Feb 2012
      • 671
      #92
      Yea i know, money for the e30 has been spread thin, so i havent been able to buy wires yet. They are pretty expensive for this engine. I need to do a bit of reading up, then i will be checking the valves. The car is parked for now, waiting to find the time to get it on stands and check all the nuts and bolts, make sure everything is still tight.
      Whenever you are ready for a dssr, let me know.
      1991 335is in progress
      • e30m3s54turbo
        • Jun 2010
        • 3292
        #93
        That sucks about the engine not running good.
        • marshallnoise
          • Sep 2013
          • 3148
          #94
          So what's the word chance? Any updates?
          Si vis pacem, para bellum.
          New Hawtness: 1995 540i/6 Claptrap
          Defunct too: Cirrusblau m30 Project
          Defunct (sold): Alta Vista
          79 Bronco SHTF Build
          • chance
            • Feb 2012
            • 671
            #95
            Nothing big. still need to nut and bolt the whole car. work has been super slow for the past few months, so play money has been pretty much non existant.
            Had to buy a new battery for it, so that could have been my new plug wires, or new tires for the front that I need.
            I need to get motivated and at least do the free/cheap stuff that the car needs.
