Adam's Glacier Sedan
  • NwEclipse
    • Sep 2012
    • 19
    So with the lsd going in I'm thinking about a mild suspension build/refresh. Thinking all new bushings, bc racing or Megan coilovers. Also thinking sway bar upgrade but have no idea what to upgrade to.
    And then brakes. Thinking brembo blanks and hawk pads. But definitely open to suggestions.
    As well as an e36 steering rack.
    Sent from my SPH-L710 using Tapatalk 2
    • HugsBmw
      • Oct 2009
      • 73
      What brand of tires are those?
      • NwEclipse
        • Sep 2012
        • 19
        Falken 512's.
        • evandael
          • Oct 2009
          • 2881
          i've heard decent things about both BC and megan coilovers. apparently you can order custom spring rates. however, you'll need a welder to install: http://www.e30tech.com/forum/showthread.php?t=91779
          if/while you have access to a welder, consider having trailing arm toe/camber adjusters welded in. use stock rubber RTABs, and talk to Carlos at Condor Speedshop for their delrin 12mm subframe riser bushings, as well as their delrin offset M3 CABs. don't forget heavier duty RSMs and reinforcing plates.
          for a cheap sway upgrade, 21mm front (from e30 convertible) and 14.5mm rear (from M3 or iX) will do you right.
          when you're looking for an e36 rack, don't get a 95 M3 one, the variable ratio is goofy. all others including z3 racks are good news.
