85 eta Turbo Build-Kamotors Build
  • Peattie
    • Apr 2013
    • 260
    this will be 4 out of 5 turbo'd e30's in reno :)
    • kamotors
      • Nov 2007
      • 7102
      I like turbos:)
      7speedshop.com
      • jtab245
        • Apr 2013
        • 23
        Turbo build almost done, still waiting on intercooler to come in the mail.
        • Dj Buttchug
          • Jun 2010
          • 7680
          hell yes!!!
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • jtab245
            • Apr 2013
            • 23
            So the turbo build is done and I have put about 400 miles on it with some autocross and it just started running lean and is not revving out.
            • kamotors
              • Nov 2007
              • 7102
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                virtual dyno-rising to 13psi.
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  Headstuds and more boost
                  7speedshop.com
                  • TheTacoMan
                    • Nov 2011
                    • 2308
                    1hp loss with head studs FTW
                    • kamotors
                      • Nov 2007
                      • 7102
                      he gained a bunch in the midrange.
                      also I overlayed the dyno's and he has more power and torque than your car below 4K and after 5800rpms.
                      and he can do roll on burnouts at 30mph now.
                      7speedshop.com
                      • blasphemy101
                        • Apr 2012
                        • 170
                        330whp at 8psi? Wat?
                        The Great Big M20 Timing Belt DIY
                        Some good information I've found online (no affiliation):
                        Turbo Tech (Garrett)
                        Four-cycle information and cam properties for beginners (ISKY Racing Cams)
                        • kamotors
                          • Nov 2007
                          • 7102
                          the first is with cracked open wastegate flapper to lower boost and it resulted in 6-8psi for most of rpm range but creeps to 13psi by redline. Thats why the power curve looks the way it does.
                          thats 15psi on second dyno done just by wastegate arm adjustment, resulted in a large torque gain and around 10whp in the midrange and around the same at peak power.
                          heres a quick comparison.
                          red lines are at 15psi with studs.
                          7speedshop.com
                          • kamotors
                            • Nov 2007
                            • 7102
                            [IMG]http://farm8.staticflickr.com/7398/10216020543_e60c7b0e06_c.jpg[/IMG
                            7speedshop.com
                            • blasphemy101
                              • Apr 2012
                              • 170
                              That makes sense. I was thinking "I make nowhere near that much power at 8 psi..." :)
                              • kamotors
                                • Nov 2007
                                • 7102
                                yeah this car is really quick. I did some scientific testing against my protuned 290whp WRX and this E30 pulls a car length on it within a second.
                                7speedshop.com
